Question about Kitchen Ranges
Hotpoint ew83 electric cooker starts to make continuous clicking or buzzing noise when either top or bottom ovens reach temperature. Noise coming from back of cooker just under the level of the hob.
3 Suggested Answers
  • 1462 Answers
SOURCE: Newhome electric cooker = problems with oven
problem is 99% sure is the cvircular element round the fan. easy to replace
Posted on Mar 31, 2007
  • 4 Answers
SOURCE: the temperature settings have been cleaned off
Try here:
http://www.manualsonline.com/ex/thread/view/idThread/3088468
Posted on Jun 09, 2010
My Hotpoint SY36 oven has started making a clicking noise behind the control panel. The temperature light does not come on although the oven does heat up still.
If you have a problem with your hotpoint cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Dec 11, 2014 | Hotpoint SY36 Style Line Stainless Steel...
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Hot Point Dryer does not come on but you can hear the noise by the start knob like a low buzz
Feel the outer cover at rear of the dryer at the bottom,if it starts to feel warm then the heater is working, the buzzing noise could be the motor trying to start, or noise from the relay, if the heater does not come on then could be timer faulty or faulty start relay. It is a a process of elmination.
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint ew83 main oven stopprd heating, fan and light ok but no heat from element
Hotpoint EW83
1. Safety Fusible Link Blown (O/C) Do continuity test
2. Temperature Control Module Faulty (Heat Sensor)
3. Main Heating Element Blown (O/C) Do Continuity Test
4. Check for damaged wiring due to arcing etc.
5. Fetch the Proff!
May 04, 2008 | Kitchen Ranges
Hotpoint BU72 Cooker - Oven not getting to temprature
Lower oven has new element but still not reaching correct temperature.
Mar 16, 2008 | Hotpoint Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
