Question about Whirlpool Calypso GVW9959K Top Load Washer
My calypso washing machine gets stuck and does not
My calypso washing machine gets stuck on a number and does not finish washing unless I adjust the plate during mid cycle. It makes a cranking sound when the plate tilts. Is it possible that the plate needs to be tightened? The repair guy said nothing is wrong with it.
SOURCE: Whirlpool Calypso - Will not start
We just experienced the same problem with the buttons! I just kept pushing all the buttons until it switched over-delicate cycle was actually the one that got it going-what a piece of work this machine is!
Posted on Dec 17, 2007
  • 1314 Answers
SOURCE: My Whirlpool washer (model LSR8233EQ0)
yes it is ,yes you can .You need a spin basket tub block and nut and a whirlpool tub wrench.You can get that at the appliance store when you buy the tub block .On the control panel locate the the two phillips screws at the back or front of the control panel at the bottom where the panel meets the base .Back them out far as you can .Pull the control panel forward and tilt it back(im assuming you've unplugged the washer first) you will see a connector that goes to the lid switch unplug it .Next you will see two gold clips (notice how they go) pop them out with a screw driver .Tilt the washer body back toward you standing at the front and walk backwards with it to remove it .Then unsnap the splash ring from the outer tub and remove it.Pull the rinse cup from the agitator under that you will see a cap remove it .Then you will need a 7/16 inch wrench with a long extension to remove the agitator bolt and pull the agitator.then you will see a spanner nut made of aluminum that's where the wrench comes in remove that nut and pull the spin tub under that will be the tub block tap it off the spin tube and slide the new one on .Replace the spin tub and nut using the spanner wrench tighten the nut tight as you can by hand then hit the wrench handle with a hammer to get it tighter.Then reverse the procedure to reassemble.When you replace the body of the washer look down through the lid opening the front of the washer body goes under the base and the sides go on top along the edges. print theese instructions its really not that hard that will fix it
Posted on Jan 27, 2008
SOURCE: Whirlpool Calypso Washing Machine
I have the same washer. Over the past weeks I have had all sorts of error codes. In no particular order, I've had: CA, CI, ld, ob, and SL. Had a repair guy come out and put in a new pump. Didn't solve the problem. Had a more experienced guy come out from the same company. We basically tore the thing apart. We found an underwire from one of my wife's bras (she wondered where it went) along with a bunch of lint in the recirculation tube. You can see the outlet of the tube at the top back of the drum. We also found one of her small booty socks inside the tub blocking the drain tube. We fished everything out and it works great again. I have a two foot long cable grabber that we needed to get the sock out of the tub. You'd be amazed at where things can get trapped in these things. So, I spent $230 or so for a pump that I probably didn't need, but the new pump design is vastly superior to the old one so I'm not complaining too much. The company didn't charge me for the repeat visits, which was nice because the senior repair guy was at my house for about four hours at the end of his day. So the more experience guy and I brainstormed about why all the different error codes came on and this is what we came up with.
CA and CI -- These are current fault codes. Either the average draw or and instantaneous draw tripped a set maximum. These were likely caused by the pump trying too hard to pump thru the blockage in the drain line.
ld -- This stands for long drain. The pump must be able to drain the water form the tub within a certain time frame, if not, you will get this error code. Again, likely came from the sock blocking the drain tube. This may have also came on because the washer recirculates the water throught its cycle. With the recycle tube clogged by the underwire and lint, the only place for the water to go was out the drain. With that being clogged as well, the ld code comes on at the beginning of the cycle.
ob -- stands for out of balance. This one confused me a bit, because I was getting an out of balance signal with nothing in the washer. Apparently, with too much water in the tub and the thing sloshing around, an ob signal is very common with the drain clogged.
SL -- is for suds lock. You can get this one if you put too much soap in the thing. It can also come if you use conventional soap instead of high effencicy soap. I only got this one once. This message can also be caused by a faulty pump.
Hope this helps anyone with these problems. I wouldn't have wanted to tackle this one myself, but probably could do it now after helping with the repair last night. I know these machines have a bad reputation, and I wouldn't buy one of these again, but when its working, my wife and I think it does a good job washing our clothes.
Posted on Dec 11, 2008
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Drum not spinning during some spin cycles
Replace the direct drive coupling.
Posted on Mar 23, 2009
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso beeping
The washer has a stuck keypad on the console. One of the buttons are stuck and the washer thinks you are holding that button in so it is beeping and will not allowing you to select anything else. It is hard to tell which button it is, although narrowing it down does not help anyway. The console with keypad is sold as one piece and would include the whole console facia and all the buttons. The model number provided is missing 2 digits on the end (ex. GVW9959KL1) and color is also needed for part number but they all seem to retail for $181 or close.
Thank you
Please rate this post
Jan 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My sheets are stuck in the spinning arm of my washing machine - not turning and can't get them out!
You might want to check the belt or the clutch
The V-belt is probably slipping on the pulley. If there is no tension spring or place to adjust the tension, try belt dressing or replace the belt.
Jun 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How do I teake apart a Whirlpool calypso to get to belt
You really need a service manual to be able to disassemble this unit unless you just want to rip it apart. Google your model # to find a supplier - they are out there - but the manual I have is Part # 8178010 and is for certain Whirlpool Calpyso models (I actually bought it as a close equivalent to the Sears version).
Jun 12, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Extra part
GVW9959K
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GVW9959K
click on your model number. In the new window click on the diagrams in the left-hand side. You will have to examine them to try and find the rubber part.
Mar 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso GVW9959Q - Black stains on whites
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer
Feb 14, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
26 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
