Question about Toshiba Televison & Video
I have a Toshiba TV/Combo The set will turn on then it turns of in a second. It will not stay on.
  • Toshiba Master
  • 12,061 Answers
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Jul 14, 2010
More detail --- Toshiba md20q42 tv/dvd combo not powering on, initially when it happened i Hit power button and lite came on and blinks for about 3 seconds then turns off--- now when i push power button...
Hi
It is probably a power supply problem associated with standby circuit. If this circuit is bad the set hardly comes on and fails. This is a task for a technician to trace the fault through the whole power supply.
Sully
Sep 22, 2013 | Toshiba MD20Q42 20" TV/DVD Combo
Tv combo is 2 years old..only use in bedroom. very little use..push the button on tv or remote, the tv comes on for a second,,then goes off..if i turn on tv with remote, and keep the button held down,,the...
This is a very common problem in these sets. I would recommend taking it to a certified repair shop. What normally happens is that the x-ray protect transistor starts to "leak" (electricity, not fluids) and shuts the unit down. The repair is not too costly.
May 01, 2010 | Toshiba MD20F51 20 in. TV/DVD Combo
I have a Toshiba DVR19DTKB DVD & VHS Recorder with Freeview , A SKY + Box, A Panasonic NV-SD240BL Video cassette recorder, A Samsung PS42B450B1W 42'' Plasma TV, and would like see a diagram of how all...
connect the aerial to the dvd/vcr/freeview combo, connect a scart from that to the tv, from the scart out socket.
you can then connect the sky from the scart marked tv to either the tv direct or to the combo if it has a second scart.
Note. a scart socket with an arrow going into a box is an input, coming out of the boe is an output and a double arrow is a two way scart.
if you use scart 2 on the tv to connect the combo, the combo will recieve a signal from the tv for recording.
Jan 21, 2010 | Televison & Video
V chip reset
i need to reset my sons v-chip how do i do that,he has a toshiba tv.
Sep 27, 2008 | RCA T20TF667 20 in. TV/VCR Combo
Television Shuts Off
TRY REPLACING THE REGULATOR OR CHECK DIODES IN SAID CIRCUIT ,ALSO CHECK FOR BAD CONNECTIONS.
Jan 26, 2008 | Toshiba MD14FN1 14 in. TV/DVD Combo
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Toshiba TV/DVD combo turns on then off again.
try letting it sit for 15-20 minutes unplugged from the wall and maybe try another outlet depending on if u got plugged in to a power strip, possibly pulling to much power from that perticular outlet.
Oct 16, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba TV MV13P2
All I can say is that the black box appears when the closed captions are on and set to TEXT. This is normal. Turning off the closed captions should make the black box go away. If the closed captions are somehow turning themselves back on, there may be an issue with the microprocessor in your TV.
Aug 24, 2007 | Toshiba MV13P2 13 in. TV/VCR Combo
Toshiba MD20FP3 radomly turns off
a loose contact on the mainboard, if you know how to solder then have patience in soldering what you can see in the mainboard that may be having loose contact.
May 14, 2007 | Toshiba MD20FP3 Combo
Toshiba MD20FP3 Combo does not turn on. Help!
Not unless you have taken the time to learn all the safety issues concerning the HI voltage safety facts, in the repair of electronics? It sounds like your tv has a problem in the sweep/power supply circuits, and since these sets have NO user serviceable parts< its best too leave these types of repairs to a certified electronic technician. Good Luck
Jun 25, 2006 | Toshiba MD20FP3 Combo
Televison & Video Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
