Question about Amana ARB2214C Bottom Freezer Refrigerator
I have an Amana bottom drawer freezer with a number of P7470205W L. The tube which drains the defroster should drain into the pan but there is a leak and it is dripping onto the floor in the back of the refrigerator. It looks like the tube is connected but the water still leaks out and runs along ithe tube and drips off brfore it reaches the pan. What to do?
Boba
  • 64 Answers
SOURCE: I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Posted on Jun 11, 2006
  • 33 Answers
SOURCE: Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
Posted on Jan 03, 2008
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
docjohn174
  • 943 Answers
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Posted on Sep 11, 2008
  • 219 Answers
SOURCE: I have a Amana 18 refrigerator which is leaking
the drain hole is in your frezzer behind the back panel
Posted on Mar 19, 2009
Where does Amana bottom freezer drain discharge to? I have manually defrosted the freezer. Water dropped into drain. Now water leaking out of the bottom at side of unit.
The defrost water drains into a holding pan and is evaporated away. The video displays the most likely problem.
https://youtu.be/_MyOFwRWRTY
Oct 22, 2017 | Amana Refrigerators
Water is freezing in the bottom drawer GEProfile bottom drawer freezer and leaking water on floor
Sounds like your drain tube is blocked in the freezer for the defrost water. The drain tube is in the back left or right corner and will have a drain trough under the cooling coils tilting towards it. That trough will probably have ice built up all over it. Once the ice is out you may need to force hot water down the drain tube. I use to use a turkey baster with a rubber hose on it to force the hot water down the drain tube. Its clear when you put water in the trough top and it goes down the tube freely to the drain pan under the refrigerator.
Feb 28, 2015 | GE Profile PDS22MHR Bottom Freezer...
Amana freezer door doesn't fully shut
There is a drain inside the freezer part of the arb2257csr. The drain can get clogged and the water from the defrost process will pool up on the bottom of the freezer. You can gain access to the back of the unit and remove the pan drain to clean it out. Then make sure water flows and ice is not blocking the drain. It takes a long time to melt so I used a turkey baster and put hot water into the drain from the lower inside middle of the freezer. This drain pan can get pretty smelly when rancid oils and such don't evaporate the way it was designed to evaporate the water. The symptoms were ice on the inside bottom and water pooling in the front of the drawer. It also became very hard to close the door due to the frozen door slide. I have not seen anyone report this on any site so far. Everyone talks about the thermostat but no one seems to have arteriosclerosis of the drain tube.
Apr 15, 2013 | Amana Refrigerators
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
My LG Model LRTN18320WW is leaking water inside frig. on bottom below produce drawer. has occurred since summer. what is solution?
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
Oct 05, 2010 | LG LRTP1231W Top Freezer Refrigerator
Amana upright freezer leaks water on floor instead of in drip pan under it.
check the flor of the freezer if it is caked with ice your defrost drain is clogged
if not
take off the back panal
under the machine follow the drain tube
to the drain pan clean out your duck bill and make sure the tube is in the pan
Oct 06, 2009 | Amana 16.7 cu. ft. / 473 liter Upright...
Leaking water frm bottom every two days a small pooling of water appears on the floor. This Amana refridgerator has the freezer is on the bottom of the fridge.
that would be a clogged drain.....take everything out of the freezer and there should be 2 to 4 screws to take off the back wall of the freezer. Break up the ice and poor hot water at the bottom where the drain is until it starts running in the drain pan. If you have a small hose to slide down the drain that will help also
Oct 03, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer leaks water!
luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
Dec 21, 2006 | Amana ABB1927DE Bottom Freezer...
Amana ARB2214C Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
