Question about Acer Aspire 5735 Notebook
Acer Aspire 5735Z Replacing the Power Jack
I have an Acer Aspire 5735Z laptop that no longer chargers no more. Through trial and error, I have wored out that it is the Power Jac /DC connector that needs replacing.
I have now bought the correct part, however how do you fit it.
  • Acer Master
  • 12,061 Answers
Http://www.eservicemanual.info/index.aspx?b=Acer&m=ASPIRE-5735&view=1240994504
This is pretty simple, go to this website above and download your service manual, it shows how to disassemble and do what you want.
Posted on Jul 14, 2010
How to replace the DC Power jack of my acer aspire 7735Z
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 7735z jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Next, Google this question and check out the YouTube videos regarding Acer DC Jack replacement. It will give you an idea as to what you need to do. You may want to take a video camera and record what steps you take when you take it apart so you can review how to put it back together. Also, get a sewing box or something so you can put the screws in a separate container for the order you removed them; ie: bottom screws; hard drive screws, DVD mount screw... etc..
You always have to start with the bottom and work your way to the top. You will have to remove the palm rest, keyboard, heat shields and any other piece of hardware to get to it.
YouTube is your friend...
Aug 12, 2014 | Acer Laptop DC Power Jack for Acer...
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Acer laptop aspire 5735z plugged in not charging
It's looks like the battery was already completely dead.
A replacement battery may be the good choice:
http://www.laptopbatteryretail.com/acer-aspire-5735z-battery.html
http://www.battery-center.net/acer-aspire-5735z-battery.html
Aug 27, 2011 | Acer Aspire 5735 Notebook
My acer aspire 5738 charge only works when i toggle the charger head and if i move the laptop it stops charging, i bought the laptop second hand 2 months ago. thanks in advance for any advice given :-)
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Alternatively, the charger wire just next to the charger head might be damaged.
Some wire has frayed apart and is making intermittent contact with itself. This could be fixed by either replacing the charger with a new one, or replacing the charger head & the few centimeters of the wire connecting it to the charger & re-soldering a new charger head instead.
Apr 18, 2011 | Acer Aspire 5720-6661 Notebook PC
I have an Acer ASPIRE 5735Z and i have a power issue
Hello, from what i have read, it seems you have'nt considered that the Battery itself may be the issue at hand.. If not, I recommend that it now becomes the focus at this time.
Apr 28, 2010 | Acer Aspire 5735 Notebook
Faulty charger point.when i plug charger in i have 2 keep still other keeps going off
If the charger jack on your laptop gives you intermittent connection, the changes are that it needs to be replaced. If you are good at soldering on PC boards you can replace it yourself. if you take it to a repair shop they will probably charge you about $90 to replace the jack.
If you want to consider replacing it yourself, take a look at
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
You can Google "laptop power jack repair" for more information and service sites.
Hope this helps.
Nov 18, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5315 randomly stops charging.
I think u just answered urself, replace the power jack should solve the problem
Oct 10, 2009 | Acer Aspire 5315 Notebook
My DVD RW device no longer recognised by PC.
Please download and run microsoft fix from this link or follow the link.
support.microsoft.com/kb/314060
support.microsoft.com/kb/316529
Aug 29, 2009 | Computers & Internet
Acer Aspire 5735 Notebook Logo
1,308 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
