Question about Microids Video Game Consoles & Games
Black screen with Still Life when start up. I have windows vista, tried clean boot, tried compatibility mode change to xp service pack 2. What can I do?
    President:
  • 567 Answers
You should remove the game from the computer, to do this you need to restart the computer press F8,then use last known good configuration,if it do not solve the problem then restart and press F8 again and select safe mode, go to control panel use system restore to restore the computer to a date before the problem started.
Posted on Jul 14, 2010
Running windows vista service pack 2 but quicken 2014 won't open
One solution would be to run it pretending your Vista is XP. I have seen it done but as I have no Vista machine, I cannot tell you the steps. Search for running Vista in XP mode - once you have managed that, try installing the software.
The second solution would be to open a virtual machine on Vista and running that as an XP machine. Again, I have seen it done.
Try the links I have added below.
The problem I had was with Quickbooks, not Quicken, but the principle is the same and worth a try. Good luck.
Use XP Compatibility Mode in Windows Vista Win7 Vista Windows XP Compatibility Mode in Windows 7 and Vista
Feb 13, 2014 | Intuit QUICKEN 2014 DELUXE
Im trying to run nhra drag racing2 on windows vista but I get a black screen when trying to play game although i can hear game music in background. the task manager screen says that the game is not...
Since the game was released in 2002 it may have a few problems running on today's systems. I would first try running it in compatibility mode. Right click on the icon you use to launch the game and go to properties. From there click on the compatibility tab. Select the check box that says "Run this program in compatibility mode for" and then from the drop-down box select Windows XP (Service Pack 3). Then click Apply and OK. Then try launching the game again and see if it runs any better. If not, try it again but in compatibility mode for XP (Service Pack 2). Good luck!
Jun 29, 2011 | Racing Nhra Drag Racing 2 for Windows
Can windows 7 run GTA IV.
Running GTA 4 on windows 7 should not be a problem. You just have to run the installer using compatibility mode. Right click on the "setup.exe" then choose Properties. Go to Compatibility tab and tick "run this program in compatibility mode for", choose windows xp sp 3. That should allow you to install GTA 4 on windows 7. Bear in mind that you have to install GfW Live and the C++ 2005 files seperately which can be found in the disk as well. More importantly, make sure that your computer meets the system requirements for the game.
Here it is: System Requirements
Minimum System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz Memory: 1.5GB, 16GB Free Hard Drive Space Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista) 18 GB Free Hard Drive Space Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
After installing the game and you're not able to run it, Try running the main executable file of the game in compatibility mode as well.
Hope this helps.
Apr 21, 2011 | Rockstar Games GTA IV
Re-installed XP Pro + SP2 + SP3 - but have black screen
reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
Sep 23, 2009 | Dell Latitude D600 Notebook
Vista boots just Black screen with cursor even in safe mode
Yes, this is a known issue with Vista. You need to back-up your data, format your hard drive and re-install Vista from the beginning.
There is really no use trying to repair it: it is damaged.
After you re-install Vista, do not forget to install service packs from microsoft.com.
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Scrapland and vista, error starting game - solution?
my friend you can go to launcher.exe and
1 right click and properties .
2 compatibility and then select mode windows XP/nt
click on the other icons try it works.
reply about the result.
Mar 28, 2009 | Enlight Interactive Scrapland for Windows
Booting is delay so much time
Try the following steps:
1. Tap "F8" key while computer is starting
2. Select "Safe Mode" from the startup options menu.
3. If the computer boots in safe mode, restart the computer and check if the problem still exists
This could happen if the BIOS update has created some changes which are not compatible with Windows Vista. Try updating the BIOS again.
Mar 25, 2009 | Microsoft Windows Vista Home Premium with...
Wireless music center PC installer V 2.0
  1. Right click on the DMM shortcut and choose Properties.
  2. Click the Compatibility tab.
  3. Under Compatibility Mode switch on the Run this program in compatibility mode for: checkbox, and choose the appropriate operating system e.g. Windows XP (Service Pack 2). Then click OK
4. Click on the DMM icon like normal it should then install.
Aug 06, 2008 | Philips WACS700 Shelf System
Win Vista and Win XP Probs?
which applications are not compatible? Do you try to run them in compatibility mode set at windows XP?
You may install VMWare Server to run a virtual machine XP from Vista without dual boot, allowing running XP and Vista at the same time, its easy to install/configure, need a good computer with 2Gb ram min.
Jul 04, 2008 | Microsoft Windows XP Professional With...
Video Game Consoles & Games Logo
580 people viewed this question
Top Microids Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Microids Video Game Console and Game Expert? Answer questions, earn points and help others
