Question about Vacuums
Belt locfation need to know where belt is located so I can change belt
  • 1 more comment
  • mchottie May 22, 2008
    hi! i have an eureka upright altima vacuum, i cant figure out how to change the belt....help!
  • jenkober Sep 27, 2008
    How does one even GET to the belt to change it??
  • DCDinodeer Jan 19, 2009
    Kirby Vaccum Cleaner
    Kirby Heritage
    Model 2 H D
    Model # 4890624353
    Ilustration on how to change belt of beater bar?
An eureka whirlwind lite /the boss how to open to get at the belt
Posted on Dec 27, 2008
    President:
  • 1,673 Answers
You did not say which brand and model number you have, and they are different. Belts go around the brush roll and the motor shaft on most models.
Posted on Apr 20, 2008
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
I need a manual for Hoover vaccum U5093-940 as I need to know how to replace the belt
Take a look at this web page:
http://hoover.com/support/video-instruction-guides/
and see if you can locate your Vacuum. This page has instruction videos for belt changing etc.
Dec 27, 2011 | Vacuums
How to replace the belt on bissell healthy home vacumn
I think this is a terrible answer.. but after researching everywhere on how to change the belt, most answers were to look up the owners manual. So I looked it up online. this is all it has on changing the belt:
"Belt maintenance
The brush belt is designed to last the useful life of the cleaner when used according to all
instructions in the user guide under normal household conditions. If you feel that it needs to
be checked or replaced, call BISSELL Consumer Services or visit the website to locate an authorized service center. Do not attempt to disassemble the vacuum foot to change the belt."
Frustrating! Good luck!
Jun 07, 2011 | Bissell 5770 Healthy Home Bagless Upright...
The bristles will not spin.
See if the belt (that drives the bristles) if is loose or need replacement.The belts are located either on the left or right side of the bristle brush(you can locate it by putting the vacuum upright and see under the brushes). If it is loose or broken replace it(walmart has replacements for it or any hardware store)just bring the belt for the replacement number written on the belt,or know the brand and model number.
Nov 19, 2010 | Bissell 3522 PowerForce Bagged Upright...
How can i get a manuel . I don't know how to hook up the parts for the shampooer to clean carpet . Need ASAP.Kirby vacuum model #293001 serial G.
I haven't been able to locate Kirby manuals, but they do have good instruction videos for hooking up the shampooer, changing the belt, etc. Just click on the video you need.
http://www.kirby.com/Portals/0/videos.html
Oct 08, 2010 | Vacuums
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Nobody seems to be able to answer the question on how to change the belt on a bissell steam cleaner ..... Bissell is horrible for never giving customers proper instruction manuels .... THUMBS DOWN FOR...
i have the same prob. this is what i found
Since changing the belt is the easiest fix, we suggest you check that first. (Before attempting any repair be sure your machine is unplugged from the electrical outlet). Most Proheat models have two belts; a cogged belt that turns the brush roll, and a flat belt that turns the pump. If the pump belt is stretched or broken it needs to be replaced. The pump and belts are located in the front of the machine on the operator’s left. Turn the machine over and you’ll see a red retainer with 2 screws. Remove the retainer to gain access to the pump and belts. While you’re there check the red pump pulley, it’s where the two belts are. If that pulley is broken or loose you’ll have to replace the whole pump, the pulley is not available separate.
on your housing you will see a plastic cover adout 4 inches long remove this piece and you should see where your pump belt goes. flip your steamer over and remove the little red retainer that sits by the belt you have located. at this point you can take your brushroll out and slip the pump belt over the pump and onto your motor. then reassemble.
Jan 12, 2009 | Bissell 1699 ProHeat Clear View Upright...
Need to replace belt
turn it over on the bottom by the roller there is a cover with 5 screws take off cover theres the belt........hope this helps
Dec 17, 2008 | Eureka 5848AV Bagless Upright Vacuum
How to change the belt
umm..yeah "how to change the belt" is phrase in an outline, or a table of contense. how about actually asking a question, slowfuck?
why do you need to change the belt? what is wrong with your brain? i mean, vacuum. head cavity. is the green light not on? did you break the belt? do you need to change the belt?
i'm not the internet psychic. i don't know what's going on inside your vacuum. you need to say these things. your question is like me saying "how to wipe my *******"
i'm not even going to answer your question...see the other posting i made, if they don't delete it for obscenity first.
gay "internet bullying activisim."
Aug 01, 2008 | Dirt Devil Vacuums
Changing my Belt
There should be 2 or 3 screw on the top housing, if not there, then they are on the bottom. Remove those screws, then the top housing comes off and the belt and brushroll are in the open.Part # 61120A long life belt. Brush roll #62365-2 if needed.
Dec 16, 2007 | Vacuums
Vacuums Logo
316 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
