Question about Kenmore HE2 Plus Front Load Washer
F33 code poped up
Just lights up now and thats it , is there anything I can do to fix myself
  • 15,935 Answers
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa#$%$
Posted on Mar 04, 2011
How to fix washer, error f33
CLICK HERE
Thanks for using FixYa#$%^
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control lights light up, washer doew not drain. F33 signal. No longer able to start a load
CLICK HERE
Thanks for using FixYa*&^%
Sep 26, 2010 | Kenmore HE2 Plus Front Load Washer
How do I fix my washer when I get the F33 code
CLICK HERE
Thanks for using FixYa!@$#$%^
Aug 31, 2010 | Kenmore HE2 Plus Front Load Washer
What does F33 mean- its the code on my front loader washing machine
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
Fuse keeps poping to my guage cluster
Does it have a non-factory stereo radio? I have seen the folks that install, wire the dash light circuit to the radio chassis ground.(many times)
Sep 27, 2009 | 1984 Ford Bronco
F33 error code. drum begins to rotate and then
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore HE2 Plus Front Load Washer
ERROR CODE F33 AND 5D
5d possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. F33 MUST be fix by a technition Service ONLY am sorry about this inconvenient. "Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi there. I have a panasonic mocrowave model no. NE-1037 When i turn it on almost everytime it gives me an error warning Error code F33 How do i stop this and why does it happen? Regards
F33 is usually a code indicating a faulty ground to the control board.
The usual culprit is the top screw that holds the control panel assy in place. Remove that screw, clean around the screw hole and lightly sand the area to insure a good ground. If you have one, install a star washer on the screw, replace, and tighten really well.
That will usually fix your problem!
Jul 23, 2008 | Microwave Ovens
Panasonic reverse cycle aircon.
Found the codes are printed inside the air conditioner.
F33 ---01. = locked up compressor.
Cannot fix this problem myself, will have to engage a serviceman.
Stan.
Jul 15, 2008 | Heating & Cooling
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
