Question about Refrigerators
Compressor not going on .evaporator worm. - Refrigerators
    Guru:
  • 1,524 Answers
Change the relay switch.
Posted on Jul 14, 2010
Testimonial: "thanks.that did it"
My breezair evaporative cooling can not cool.
Maybe you're expecting too much. Evaporative cooling doesn't work really well. It's function depends on evaporating a lot of water into the air. If the air in your room doesn't have a really low humidity (really dry air), then evaporation can slow way down or even stop regardless of how fast the fan is blowing.
Jan 02, 2015 | Heating & Cooling
My breezair evaporative cooling system can not cool.the air flow is very worm,anyone can tell me this problem?
what is the weather like is it humid ?
Humid weather will render any evaporative cooler ineffective !
Have you got the windows and doors open to the building ?
Evaporative cooling relies on putting water in the air and pumping the air out of the building. If it is humid the air already contains water and no extra water is added to the air and no cooling occurs.
Where is the AC drain line for a 2004 xc90?
If the a/c runs for 10-15 minutes and then blows worm, it would not be the drain line.
Check and see if the outside blower ( cooling ) fans are engaging.
If they are not running, the unit will run into a high pressure overload and open power connection to the compressor.
Also, you may want to check the Freon level.
May 15, 2014 | 2004 Volvo XC90
Bi passing low pressure switch a/c compressor does not work in worm conditions
I suspect you have a low refrigerant charge in the system due to a leak, leaking AC compressor shaft seals are common in this year. Have a shop confirm the pressures in the system are within specs
Jul 26, 2012 | Cars & Trucks
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Apr 27, 2012 | Refrigerators
My KitchenAid KTRC22KK leaks below when hooking up to water line. The leak is not at the connection, but under the refrigerator. ???
Hello, You would have to pull the unit out away from the wall and remove the rear panel down the bottom that gives you access to the compressor area. You can see if the leak is coming from either one of the water lines or if the leak is coming from the compressor drain pan. The compressor drain pan is where the water that is defrosted off the evaporator coil goes down a hole with a tube attached to it into this drain pan in which the compressor fan in the unit is supposed to evaporate the water. Try removeing the rear panel on the inside back wall of the freezer couple 1/4" screws. This will give you access to the evaporator coil. If you see any ice build up on the evaporator or under the evaporator blocking the drain then your unit would be having a defrost issue. Message me back after you check for the defrost issue and also the compressor drain pan if these are clear then you would have to diagnose if your unit had water or ice going to the door both of these water lines. I await your reply Thanks Rick
p.s if your unit does have water going to the door also assure the connection that goes into the bottom of the door is not broken or cut as well I will look up your schematic when you respond if you need me to point out any areas of this repair
Aug 14, 2011 | KitchenAid KTRC22KK Top Freezer...
Temperature is to worm in Freezer
Could be any one of these problems
\ evaporator fan not working
\ ice blocking air flow
\ thermostat worn out
\ low refrigerant charge
\ blocked or dirty condenser
\ poor air flow over the condenser
\ compressor valves burnt
Mar 24, 2011 | Gladiator 19 cu. ft. Chillerator Garage...
I have 10 years old Profile, side by side refrigerator, model TPX24. Today there was water on the floor, ice was melting, and the top part of refrigerator was wormer then the bottom. I defrosted it. water...
If you can hear the compressor come on, then I would suspect that it needs either freon or a "cold control switch". Usually it is not the switch. If the compressor tries to start but just makes a brief buzzing noise and then shuts off, then the compressor may be bad.
Jun 24, 2010 | Refrigerators
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Refrigerator evaporator fan won't run but compressor working
is the evaporator coil frozzen you may have a defrost problem
Mar 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
102 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
