Question about Aiwa Audio Players & Recorders
Aiwa mx 70 Amp powers on, no blown outputs, the
Aiwa mx 70 Amp powers on, no blown outputs, the speaker relay won't come on. Problem got worse from leaving the unit on for a minute, to 5 minutes or longer before the relay kicks in to now it doesn't kick in at all.
  • 13 Answers
SOURCE: No output to the speakers from any source
It seems to me that u have an output problem. ckeck the output components (either IC or transistor)and change them. good luck
Posted on Dec 21, 2006
  • 979 Answers
SOURCE: Power on problem
Time for a little repair here. It seems that one or more channels have developed an excessive drain on the supply, and has caused the threshold to trip and shut you down. It's more than likely shop time at this point....accordianman
Posted on Oct 25, 2007
SOURCE: Denon DRA-25/25L Stereo Receiver.
Without looking at the schematics for this particular model, I'd surmise that the click is indeed a speaker protection relay. Generally this is fed by a number of different sense circuits that watch for power amp issues and/or excess speaker current and/or power supply output stability. Although the relays do indeed fail at times, generally it is not the relay that is at fault. If you have a scope and a schematic, you can check the various circuits that feed the relay for the exact cause. If not, you can do some experiments that might help deduce the problem: e.g. do headphones work when speakers do not, does the relay click on when no speakers are connected (or selected), etc. In my experience, it is most often the output transistor(s) in the power amp. But not always ;-)
Posted on Oct 15, 2008
hokuwho
  • 306 Answers
SOURCE: My bose car stereo system
The problem is in the power amplifier section. If you a preamp out connector you can troubleshoot using another power amp between that and the speakers but you may need a schematic to isolate to the components at fault. Bose is worth fixing and if you can remove it yourself you will save money by getting it to a bench technician, even a TV repair shop can fix it. Steve Medley
Posted on Nov 08, 2008
  • 4234 Answers
SOURCE: no audio output - Marantz 2238
This can be as simple as a poor connection somwhere in the voltage regulator circuit or a defective driver transistor or output transistor. In any case, this is a simple repair for any shop that works on vintage receivers. If it is the outputs, that will be the most expensive repair from a parts perspective. The outputs will cost in the $5-$10 range for each one and it could be 2-4 pieces. If you wish to attempt this repair yourself, you will need a multimeter that has a diode checker. Let me know and I'll provide additional details and instructions.
Dan
Posted on Apr 06, 2009
How do i hook up my Aiwa 90 watt self powered subwoofer to this Onkya A-8037 stereo amp there are only two auxiliary ports in the back and both are used by the stereo.
Your powered subwoofer should have two different pairs of inputs - one is a line input that is connected to a subwoofer output on your amp. The other inputs are those that are directly connected to the existing speaker outputs on your amp.
When you have all working make sure that the sub output is in phase with your other speakers lest you have bass cancellation.
Jun 20, 2015 | Car Audio & Video
How can i repair amp
Looks like the amplifier output transistors have blown (hence the pop). Quite expensive too repair - I would have a look on eBay for a cheap used but working Kenwood receiver, it would probably work out cheaper.
May 10, 2014 | Kenwood Audio-video Stereo Receiver Kr...
Pioneer VSX-519V Multi-channel receiver won't turn on.
You could have blown the fuse in the unit, or worse still blown the output device(s) in the power amp.
Dec 30, 2017 | Pioneer Audio Players & Recorders
My aiwa av-x200 click right off when I turn it on, Im thinking it is a blown fuse or something, anybody fixed any receiver with this problem?
The unit is going into protection mode. There is a fault detected in either the power supply or an overload on the output circuitry. Remove all connections to the amp (ie speakers, dvd players etc etc) Turn the unit on. If it still turns off the problem is internal and should be looked at by a qualified technician.
Feb 09, 2010 | Aiwa AV-X200
I have a pioneer receiver..vs 812....and sound has ceased to come out of it. It comes on....and switches between sources...but there is no signal coming from ANY source
First make sure the speaker A/B switch is on.
If still no sound, dissconect ALL speakers from the rear of amp.
Now turn on amp and listen for the relays to click in.
One relay will click when you press power. A couple of seconds later, the speaker relay will click in.
If it does, you could have blown outputs, bad speaker wiring, faulty speakers.
If it does not, the speaker relay may be faulty.
Hope this helps.
Sep 12, 2009 | Pioneer VSX-D812 Receiver
Power lite is on but nothing happens when power on is pushed
Check your Speaker control button. Most receivers have a small button on the front used to control your choice of Speaker Set A, B, A & B, or NONE. It's possible you have inadvertently pressed the button and set it to where no speaker set is selected. Therefore, no sound.
Another probable cause is that one of your speaker cables may have become dislodged at the back, and if your system has an overload control mechanism, it's preventing sound to come out to avoid damaging your output transistors, your speaker system, or both.
The last (I hope not) possibility is that the volume may have been cranked up too high, that either the output resistors may have blown on your receiver, or your speakers may have given out the ghost due to too high a signal.
Aug 17, 2009 | Aiwa AV-D57 Receiver
Standy mode system wil not turn on
When you connected the speakers, one of the following may have occurred: 1) Crossed the wires (smoked the outputs) 2) Presented too low an impedence load to the amp section (overheated and smoked) There are other possibilities as well, but those are the most common. In any case, try disconnecting hte speakers altogether and trying to turn on the system. If it turns on, then the problem is either the wiring or a bad speaker. If the system stil won't power up completely, then the output section needs to be checked. These units have discrete output transistors that can be checked by a service shop. These are not too expensive but are somewhat unique to Aiwa systems. Figure on $20-$40 for parts. Dan
Jun 15, 2009 | Aiwa Audio Players & Recorders
Power to Amp but no lights and does not switch on
(1)When the unit is switched on the relay clicks in,but no sign of life, and then five seconds later the second relay clicks on/off don't know which. This symptom is DC outputted to speaker terminals. Check any DC at power amp stage output.(2)Must have blown up.
Positive. If Caps blew, your amp shutted itself down within 5 seconds due to + & - power supply creating an unbalanced +B & - B voltage not allowing your amp to turn on.
Oct 05, 2017 | Optimus STA-3500 Receiver
MPA-101 Amplifier powers on, receives source signal, the fuse is not blown inside, but no sound comes out of the amplifier. The amp is pretty new, doesn't even have dust inside the unit.
Hello, is this a Radio Shack PA amp or Jamo amp? The unit is probably in "Protect" mode. Is this a PA system or a receiver...receivers have a protection circuit that will not let the speaker relay activate if the amplifier output section is shorted and sending voltage towards the speakers...so they won't fry!!The speaker relay should activate within 3 to 5 seconds if your output section is ok.
barneyluc
Oct 13, 2008 | Audio Players & Recorders
Leem m86t power mixer amplifier
probably blew the amps or the pre amp section
Sep 09, 2008 | Car Audio & Video
251 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
