Question about RCA D61W20 61" Rear Projection Television
Larger than life! Screen is in zoom mode and cuts off the heads
Everything else works fine it just has zoomed in and only looses the top portion of the screen. Does anyone know what to do? I have no remote or owners manual some guy just gave this to me.
TV is a 61 inch RCA Model # D61W20 or D61W20B UL/FDA Model #.
Thanks!
Bill
  • 176 Answers
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
Mar 17, 2014 | JVC Televison & Video
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
Jul 23, 2012 | RCA 47LA55RS 47 in. LCD TV
Heads are cut off off
It sounds like you may have the zoom mode enabled on the TV source. A lot of HDTVs have settings for how different modes like 4:3 format source video is displayed such as Normal, Full, Wide, Zoom and Wide Zoom. Each signal input may have a different display mode and that is why DVDs look ok and TV does not. Not all TVs have that feature but most of the ones that I have dealt with do.
It may also be a screen centre adjustment in the cable box or satellite receiver.
I hope I was able to give you a viable solution.
Cheers
Jan 04, 2009 | RCA R52WH73 Projection Television
Projected image is slightly oversized im 16 Standard Mode
The problem was with my cable providers (Knology) cable box settings. Somehow they had changed to zoom 1. I think this happened when I played a VHS tape. If this keeps happening everytime I play a tape or DVD I'll have to remember to reset the vidio on the cable box after each tape or dvd.
FLCoyote
Nov 30, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Picture larger than screen...
If you go to 4:3 mode and the picture is still cutoff then i would assume the tv has a problem with the horizontal or the pinchusion correction circuit . This would be the only two areas that would cause this problem . Check the format section of your menu to make sure it is not in zoom mode or otherwise if it is not then you have a problem with one of two above mentioned circuit problems . Good luck
Feb 01, 2008 | Sanyo DS31520 31" TV
I cannot reset the picture to Normal (which should fill the entire screen). f
on what dvd player also has zoom mode set it at 16.9 on all units once no zoom in or do u use dish hd page up down will adjust size also
Jan 31, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Difference between the D-400 Zoom and the D-450 Zoom
The D-450 Zoom is an improved version of the D-400 Zoom. Both models have the following features: •1.3 megapixel resolution •3x optical zoom lens - 2x digital telephoto •Stream-lined compact form design •Automatic focus, metering, and white balance •Built-in, pop-up electronic flash •Real-image optical viewfinder •LCD monitor •Buffered RAM memory; burst shooting •Video output to TV •12-second self-timer •8 meg SmartMedia included. Larger capacity cards available. In addition, the D-450 Zoom has the following features: •A larger buffered RAM memory permits rapid shooting (real-time shooting without having to wait for the image write) and a true sequence shooting in more quality modes: Memory Card Storage Capacity Shots Frames per second Quality Mode 10 2.0 SQ 8 0.8 HQ 4 0.8 SHQ •A new high-resolution glare-free LCD monitor screen that can be easily viewed at any angle and even in bright sunlight. The new monitor also uses less power •Automatic ISO adjustment from ISO 160 to 640. Manually selectable ISO 160, 320, and 640 •New Slow-Synchronization flash mode which enables the use of the flash on shots requiring long exposure (such as night time photography) •Image playback now includes an easier to use index mode of 4, 9, or 16 images. A 3x magnification inspection mode allows easy viewing of image detail •Overall power efficiency has been improved. 1.5 to 2 times more battery life compared to the D-400 Zoom •D-450 Zoom comes in a Champagne Gold finish NOTE: The D-450 Zoom digital camera does not include the Olympus FlashPath floppy disk adapter (which was included with the D-400 Zoom). The FlashPath adapter is available as a separate accessory.
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
RCA D61W20 61" Rear Projection Television Logo
190 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
