Question about Hobart 29 in. AM15-1 Free-Standing Dishwasher
Hobart commercial d/washer can't stop water from spraying top/bot
The dishwasher constantly sprays water then it becomes very strong pressure. We need to shut of water suppy to the unit to stop the water. Is this a bad pres. reducing valve or an issue with the dishwasher itself. This happens even while unit is off, not in any cycle.
Thanks in advance
    Genius:
  • 1,075 Answers
Try not to turn off the water supply,if i where you i would get this machine checked out.What i cant understand is the machine spraying water when it has power of.adrian,,,,
Posted on Jul 14, 2010
Moyer dieble sw400 - is there. Way to lower pressure of water sprayers? The pressure is so high the floor keeps getting wet as the water is spraying through the curtains.
No there isn't, but if water is spraying through the curtains on a commercial dishwashing, ware washing machine. Check that there is nothing partially blocking the jets, and also replace the curtains if they are not in good repair.
You need the pressure to get everything clean.
May 08, 2016 | Dishwashers
Coleman 2400 PSI Pressure Washer - WATER LEAKS OUT = ?!? Help me please!!! ((-:
Usually, there are spaces between the pump and head portion of the pump. This space is not sealed and will allow water leaking past the seals to come out. There may be a seal kit available, however I have had better luck just changing out the whole pump. There are many available on ebay. Search for one that will use same mount and hoses. Once the seals are gone, the pump will never be the same (may nickle and dime you the death).
Oct 30, 2011 | Garden
Starts ok wrench appears heats ok wash cycle pressure strong at first then fades wrench appears -p2 -cleaned screens and checked spray arms .incoming water pressure 20 psi whats wrong ?
Check the spray arm. Machine water pump. After this pump pressure
builds up to the spray arm. Rubber hosejunction inside the wash tub.
This place gets connected to the spray arm system.
You can see this when you draw the tray for loading vessels.
Slowly push it and watch the junction where this gets locked into the
rubber hose mouth inside the wash tub. There should not be any
water pressure leak.
Sep 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dish washer problem
check water going into unit. disconnect to make sure there is a strong pressure going through.
check the water valve with a meter if there is continuity the valve is good. if not the valve is bad a no water water will go through. let me know if this helps
Feb 23, 2010 | Dishwashers
Water spraying up at the back top of the dishwasher
there is supposed to be a baffle on the inside that prevents water from directly spraying out the vent. If it has broken off, a replacement will need to be welded or bolted on
Feb 11, 2010 | Hobart AM14-253 Free-standing Dishwasher
Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Jan 10, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher does not spray hot water
Can you give me a little more detail?Is this part inside or outside the machine?Any wires connected to it?What do you mean by base water source?I'm a hobart tech.
Feb 25, 2009 | Hobart AM14-253 Free-standing Dishwasher
Hobart Dishwasher
I guess I didn't understand your statement of the problem. If you know that the washer has gone through an entire cycle, and it is time to take out the RINSED dishes, yet the washer turns on when you do this, play with the door interlock and the door handle switches. If the cycle seems to have stopped, but you timed it from the beginning of a new cycle and it hasn't done all the steps, and it sprays when you open the door, then you may want to remove the timer motor and clean the contacts/ check for tine damage along with checking the door switches.
Aug 26, 2008 | Hobart Dishwashers
... calling Master_Tech Bosch Dishwasher SHU43C07UC
Hello Mary, I checked on your dishwasher and what you have is a pressure fill dishwasher. This unit has a pressure switch to make sure the water level is correct. When the dishwasher is full of water (the indention that is around 2 inches in from the side walls and front) is where the water level should be out to. If the water isn''t out this far, then the pressure switch is shutting off early and not filling properly. I read your entire essay, it is perfect, so this sounds like an issue of either not enough water, or the circulation pump impeller has separated and not creating enough water pressure at the wash arms. Since you stated that you removed and cleaned the filters, that shouldn't be the issue. That is normally where I find this issue at is clogged filters, espically in hard water. I have seen results in the pass where too much detergent was used causing the pressure switch to shut off early. In those cases filling the detergent dispenser with cooking oil and running the longest cycle removes the excess detergent. It is proteins that the detergent is designed to break down. So quit worring about your water pipes, the issue is with the dishwasher. Hope this helps.
Feb 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
187 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
