Re: Sony CCD-V701have a blinking arrow and camera does...
THIS MAY SOUND A LITTLE STRANGE,BUT FIRST, HIT YOUR RESET BUTTON, THEN SET THE CORRECT DATE AND TIME. THEN POWER ON AND OFFA FEW TIMES. IT WORKED FOR ME.GOOD LUCK.
OPEN YOUR VIEW FINDER DOOR, AND THERE SHOULD BE A SMALL PINSIZE HOLE TOWARDS THE BOTTOM OF YOUR MENU BUTTONS. ALSO, USE SOMEHING AS SMALL AS A SAFETY PIN TO PUT IN THE RESET HOLE. I HOPE THIS WORKS FOR YOU.OPEN YOUR VIEW FINDER DOOR, AND THERE SHOULD BE A SMALL PINSIZE HOLE TOWARDS THE BOTTOM OF YOUR MENU BUTTONS. ALSO, USE SOMEHING AS SMALL AS A SAFETY PIN TO PUT IN THE RESET HOLE. I HOPE THIS WORKS FOR YOU.
You can't post conmments that contain an email address.
your protection switch is jammed to the on position its a ver small slide arm insert tapes take them out and give the camera a little knock try to spring it back into off mode
hi! The problem is with the CCD which is the sensor when it is defective the pictures get disturbed also.Please replace the CCD from any service center,
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD. If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor. Qualified camera tech will replace ccd imager chip. Thanks.
Your camera ccd-TRV328 has defect with ccdimagerthat's why not giving picture in camera / recording mode. This part (ccd imager) needs to be replaced and good news Sony will replace it free of cost.
Please click Sony Official Website for details.
Regards,
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Where is the reset button on the CCD-V701.
I can't seem to find it.
Thanks
