Question about GE JKP27 Electric Double Oven
My oven will not turn off. Can you tell me why
My oven will not turn off. I have to unplug it for it to go off. I think that the ignitor is acting up. What do you think.
    President:
  • 1,891 Answers
I think the oven that you have is electric and it does not have a ignitor. and that the oven thermo has shorted contacts and this is why the element will not turn off . it may also have run a way tempts . . so if the tempts are to high and cn't control tempt // replace the ocen control .. mm
Posted on Jul 16, 2010
Magic Chef oven won't lite. The ignitor glows red hot but no flame. After about 10 minutes of being on I start to smell gas. Not a strong smell but its in the air. I'm thinking gas valve. I did a...
The problem with your oven is that ignitor is weak and not drawing enough amprage to open the gas valve, the gas you smell was since the ignitor does come on it allowed the gas valve to open a wee bit but since ignitor is weak it wont allow gas valve to open fully. I know you going to doubt that what i'm telling you is correct, i base my diagnosis on my 30 years experience as a appliance repair technician.Replace ignitor and enjoy your baked meal
Gene
Jul 30, 2011 | Magic Chef 9122 Gas Single Oven
I have an Amana ARG7102W P1143347NW gas range that the oven will not light. All other functions work including the broiler and the oven ignitor glows brightly. I don't think it is getting gas to the...
most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
Jun 12, 2011 | Amana Ovens
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
Our Kenmore oven has stopped working. We were thinking it had something to do with the pilot light going out, since we do smell gas when we turn the oven on. Can you tell us where the pilot light might be?...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 09, 2011 | Kenmore Ovens
I have a Maytag Oven Model CRG9800BAE Will not ignite gas when turned on.
are you saying that when you set it to bake the oven doesn't heat or are you talking about the top burners?if it's the oven you have a bad ignitor, the oven flame should lite in under 40 seconds to a minute,if it doesn't it's the ignitor,part number 12400035 and it's around 80 bucks.unplug it or kill the braker,take out the racks,remove the bottom panel or oven floor,take off the wing nut and remove the metal cover and you'll see the burner tube and the ignitor,,with a wet paper towel wet the screw threds on the two screws with water so they don't strip out and then remove the two screws holding the ignitor on,trust me it works.if you have to, unplug the ignitor or if it's not the original ignitor cut the two wires at the end of the old ignitor and connect the new ignitor with the ceramic wire caps and remove the burner tube if it's hard to get at the ignitor screws.put it back together and the ignitor should lite the flame in less than a minute.let me know how you make out
Aug 22, 2010 | Ovens
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
What amps is the ignitor supposed to pull to engage the gas valve in a magic chef gas oven? The top burner all work fine.
I was once told it was 3 to 4 amps but most techs just replace the ignitor and test the machine for 3 or 4 cycles. if it does not fix the problem then we change the valve. It's hard to put your amp probe in the oven that is going to start shooting out a flame.
Most techs can look at how the ignitor is glowing and tell if it's bad or good by how bright it glows.
As always make sure you unplug the machine befor changing a part.
Jan 11, 2010 | Magic Chef 9112 Gas Double Oven
Ge extra large self cleaning oven xl44 mode jgbp28ded1wh
Check to see if the ignitor glows in the oven. If it does not come on or comes on very dim, you have a bad ignitor. It is usually a bad ignitor. They are very simple to replace. Just unplug the oven first. Then take off the bottom of the oven floor inside the oven to access the ignitor. the ignitor has 2 wires going to a plug, just unplug the plug and remove the mounting screws. Take your ignitor to a local appliance store to get a replacement. There are 2 models of ignitors so bring the old one with you to make sure you get the right one. Good luck..
Oct 07, 2008 | GE JGRP20 Gas Single Oven
Frigidaire FGF326ASA gas oven
If both the broiler ignitor and the bake ignitor are not working it is unlikely they are both bad. You may have another problem. Need to check voltage to the ignitors to be sure.
Apr 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
200 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
