Question about Zanussi FLA1201W Front Load Washer
The machine will not reset after overloading it whenever it goes to revolve it trips the fuse
  • Zanussi Master
  • 12,061 Answers
Hi, this is quite a bad problem, what is happening is when the motor tries to engage it's drawing too much current and blows the breaker. Most likely you have a bad motor?
www.serviceforce.co.uk/pdfs/U20460.pdf
http://www.zanussi.user-manuals.com/zanussi-c-2.html?page=59&sort=5d
In any event you will need a service manual to troubleshoot and repair. Above are your manuals sites. one free the other pay for.
Posted on Jul 14, 2010
Won't turn on
Hi Sab, you need to replace the thermal fuse on the ascaso dream. Ascaso dream safety fuse
Mar 17, 2014 | Ascaso Dream Espresso Machine
What does overload mean?
It means you have overloaded, ie: forced too much, or, too heavy a load through the machine and rather than burn up, or seize your motor, an overload sensor/ switch has tripped. I'm not familiar with your machine but there is often more than one level of protection in a circuit. Some reset automatically, some have to be reset with a small pin and others might even have a fuse. First, unplug machine and do a visual to identify and remove any obvious sources of the jamb. Second, plug it back in and start with a lighter load.
May 31, 2013 | Royal Office Equipment & Supplies
Hi I have an Indesit is70c dryer it seems to work fine for 10-15 mins but then trips the fues box in the house as it cuts out. I've had a look for at the fuse and have cleaned out all filters / condensers....
Do not overload the dryer as the motor can struggle and try to draw to much power.which could cause the trip to go to out, only load drum half full.....this applies to washing machines as well"NEVER OVERLOAD THEM" with washing machines it can affect the quality of your wash as well as putting extra strain on the motor.
Nov 08, 2017 | Indesit IS70C Electric Dryer
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
BELTLESS BRUSH WILL NOT REVOLVE
I bought my parents the exact same model. Do you have the floor select switch "ON" for the brush? Did the overload protector switch trip? There is a little red button sticking out from the right hand side of the head. Check to see if it is pertruding past the cover. If so, push button in and it should reset.
Feb 05, 2010 | Kenmore 31912 Progressive Direct Drive...
Fuse in plug tripped whenever i reset it trips again when i plug it
check the rating of the breaker and compare it to the appliance load...it might be overloading the device
Aug 11, 2009 | Daewoo DWC-056CL Air Conditioner
Washing Machine Smell and Stopped Working
thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
Apr 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Mar 25, 2008 | Karcher DE4002 Steam Vacuum
LG 1285
Lg washers used to carry a 3 year warranty.check warranty as requires a new stator.
Jan 05, 2007 | LG WD-1280FHD Front Load Washer
Zanussi FLA1201W Front Load Washer Logo
190 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
