Question about Fujitsu LifeBook P1510 Tablet PC
Want to install Windows 7, BIOS does not recognize DVD Drive what can I do to still install Windows 7?
  • anthony_boli Jul 14, 2010
    What do you mean by upgrade? A BIOS upgrade, or an OS upgrade? I am running Windows XP Tablet PC, it has been updated as far as possible.
  • 394 Answers
You have to upgrade the system
Posted on Jul 14, 2010
During restore windows i found error "Windows could not complete the installation. To install windows this computer, restart the installation.
Reboot windows without any CD in drive and tap F8 key before windows screen appears. Select safe mode from the menu that appears and elect to do a system restore.
If this doesn't work you could try changing the boot order in the bios ensuring that your hard drive is first boot device. should get into bios when starting PC usually F2 or del key. remember to save changes in bios normally F10
Oct 13, 2012 | eMachines E730, Core i3-330M 2.13GHz,...
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 13, 2012 | Toshiba Portege M400 PPM40U01000E Tablet...
My lenovo G450 is not installing windows 7 ultimate.I had windows xp and vista but cd is not taken on boot up although the cd is bootable and i have installed 7 on my desktop but not taking on lenovo G450....
The Lenovo G450 is quite compatible for Windows 7, there could be following reasons:-
1. The CD/DVD Drive may not catch the CD/DVD becuase of lens may gone dusty, clean the lens. 2. DVD/CD may be damaged due to scratches, try another CD/DVD 3. Check the Boot options from BIOS, it must be CD/DVD on first boot
Good luck, and do rate the solution if got help
Dec 10, 2010 | Lenovo Tablets & eReaders
Missing boot manager
go to system bios (using F10 key on the start "Commanly") then press F9 for restore defaults, and insert the Bootable Vista DVD into the drive, it will solve your prob.. otherwise in bios mode make sure that all the drives (HDD & CD/DVD Rom) are properly installed.
good luck
shafky
Jun 19, 2009 | Tablets & eReaders
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
2 Compaq TC 1100 - neither boots
Try first to clean you memory using the eraser and put it again. Then u can use flashdrive in installing your windows. It can be that your cd/dvd drive is the problem. Hope this can help.
Mar 27, 2017 | Compaq D70045-236 Tablet PC
Loading OS
Cannot boot from External device
Check out this link. This should resolve your issue.
Regards
Aug 30, 2008 | Toshiba Portege 3500 Tablet PC
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Fujitsu LifeBook P1510 Tablet PC Logo
254 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Michael Vincent Cruz
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
