Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
My freezer high temp light is on and it isnt running It is 2 years old and it is a Frigidaire Upright Freezer with digital temp on the outside of the freezer. My son went out to the garage 8 hours ago and the freezer was beeping. he unplugged it and plugged it back in and it hasnt been running since
  • Frigidaire Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 20, 2010
Upright self def. freezer not getting cold
Is your compressor running? Try this: place your hand on top the compressor, quickly-in case it's hot-it should be vibrating and cool/warm to the touch. If it's not running then the cheapest/fastest test is to try a 3in1 start kit from a local appliance shop. The 3 in 1 start should be around $14 to $20 to wire up. It's extremely simple to wire up, just ask the clerk at the appliance shop's parts counter and they will explain it. I hope this helps you out!!! :)
Nov 19, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Frigidaire upright freezer. Power coming into freezer. Light inside works, and the temp setting on the door works. Not getting any power through the system to the compressor.
Contact a professional. The power supply source needs to be testing to the compressor and see if the power is fine, or if the compressor is faulty and not drawing needed power.
Aug 15, 2012 | Frigidaire Freezers
The high temp light is on, liquids are now liquid,but the meat is still frozen. I live in west central mich, and the temps have been in the high 80's and low to mid 90's with relitive high humidity, about...
Not normally,Make sure you door is sealing properly also check and make sur ethe evaporator fan is running when the freezer is in a cooling mode.you may need to remove the rear panel of the freezer and check for frost build up.if there is frost build up then defrost the evaporator with a blow dryer.
then check the continuity of the heating element and make sure it is in working order.
Aug 31, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
2,417 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
