Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
On off switch pops on with slighest touch, passes lowest speed, goes to 3 or 4,assume i need new switch, wonder how difficult it is to replace? thanks Kent
I had the same problem. I fixed it by cleaning the switch and the slot that it slides in. The slot has little notches in it and the switch has a little tab on the bottom of it. If crud either gets in the little notches or around the tab then it won't stick in position. I think you could pretty much get it fixed by scraping the crud out with a toothpick. It's also possible that the screw inside the machine that the switch pivots on has come loose, but you have to take the whole thing apart for that one.
Posted on Aug 27, 2010
Kitchenaid rrk5a not operating in lower speed settings
The RR of your model number stands for reconditioned, your actual model number is K5A, I believe that the side trim band says Hobart on the side, if not you may have a new trim band (Generic type) put on during the reconditioning to pretty it up. In any event in the back of the mixer is an end cover, at the top is a small Phillips head screw, remove it and lift the end cover up and slightly out, (because there are two small and fragile clips on the back that can be easily broken off, they help hold the end cover in place so up and out ) once the cover is removed you will see a black and copper plate with three chrome screws on it in an upside down triangle shape, the two top screws are for adjusting speeds from stir to 6, the lower one is for adjusting speeds from 6 to 10, Turn the screw on the top left to the left a quarter turn while the mixer is in the stir position. it should start turning. if not turn the screw on the right a quarter turn, the mixer should start, if not turn back the other way (both top screws a half turn) if it machine does not start then there is a strong possibility that it is the bottom screw, the bottom screw can and sometimes does get turned in or out due to the pressure caused by contact that it makes with the speed control switch bar attached to the side speed control switch, so let's try that one, turn it counterclockwise or clockwise (no more than one full turn) a quarter turn at a time, if it is the bottom center screw causing the problem then it should start within a full turn, try not to turn the screw in either direction more than one full turn as you can really screw up your speed settings. Don't panic I am probably making it sound more difficult than it really is, just remember that a little is a lot. I am a KA tech and every machine that I have worked on that has a low speed not working correctly it has turned out to be these 3 screws.
If your machine goes to high speed from the get go no matter where you put the speed switch, well that is another problem, but if your machine is not working on lower speeds when set to the lower speed and it does work at higher speeds when the switch is set to the higher speeds then it is the 3 adjusting screws on the speed control plate. hope this helps if not let us know
Jan 20, 2013 | KitchenAid Food Mixers
My mixer will spin but the 2 lowest speeds sound awful, like something is grinding and it goes too fast. It is fine if I go up to level 3 or above. What do you think is wrong and can this be repaired at...
you probrobly have a gear inside missing some teeth, so the slower you go the more you can hear the grinding, i would un plug it and take the housing off and check the gearbox, maybe the intermediate gear is going bad.
Jun 12, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer won't shut off
Sounds as though the switch has shorted? Or the speed controller has failed ON. You could try a replacement if one can be had?
Feb 03, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
KA Mod K5SS: no longer have variable speed; only 3 of the lowest
Hi. Go to mendingshed.com. Look up Kitchenaid Mixer Parts. Near the top of the page locate their FREE Kitchenaid Service Manual in Adobe format. Download it. This valuable document will help you with your troubleshooting of the speed control and anything else that needs fixing. This manual supports your K5SS. Mending Shed also carries Kitchenaid parts.
If you order parts from Kitchenaid, be prepared to wait at least a month for them to arrive!
If this solution has assisted you, please rate it. Good luck! ricardok45
May 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Classic mixer changing speeds by itself ?
Contact Kitchenaid Parts and order a new speed switch. Be prepared to wait a month for it to arrive. It's relatively easy to replace. Be sure to unplug the mixer first. Make note of which wire goes where! If the switch goes bad again in the future, buy a different brand of mixer. ricardok45
Dec 15, 2008 | Food Mixers
Mixer speed switch is haunted
The likely problem is the Hall Effect sensor located on top of the motor. This sensor is used to determine the speed of the motor. Since it does not sense a speed, the motor revs to top speed and shuts down. You have to shut the switch to Off/Reset to try again. Replace the sensor which costs under $10 before replacing the speed control which costs $50.
Dec 02, 2008 | KitchenAid KP2671 Professional 6 Series...
Hobart A200 noises
Hi, here is my opinion: 1) your planetary, or attachment hub is making the noise as it goes around, and there is grease in the gear ring that keeps it lubricated, it may be as simple as removing the planetary grease ring ( the chrome ring), and taking loose the bolt and lowering off the hub and cleaning the old grease, and installing new, reassemble in reverse. You may also have bad bearings in the shaft portion of the planetary ( the shaft your attachments go onto) allowing the shaft to "wobble" a little bit causing a slight misalignment as the smaller gear goes around while mixing. How far you want to go is up to you.
For your other problem, I have seen the brass clutch bearings stick on the main shaft in the transmission, causing the planetary to momentarily speed up, or to maintain a wrong speed ( 2nd or 3rd) when set to first, but that would require full disassembly of the transmission. Best left to someone who has done it before, but if your inclined, go for it, but get a part breakdown first, or take pics as you go. Hope at least some of that helps, and thank you.
Nov 25, 2008 | Hobart A200 Stand Mixer
How to disassemble Black & Decker MX50 PowerPro Mixer
You can remove the handle-back by gently prying the rear clips down and away. But the problem is the power boost button; it has a fork that goes down the left side and snaps over a micro-switch. You need to get that off since there is not room for all 3 buttons (eject, variable speed, and boost) to slide through the handle. A small probe inserted from the top and pushing on the left side to the rear might do it. Or just pry the boost switch upwards; that's how I got mine apart. My problem was the boost microswitch was bad and provided a poor connection. As a result, the beater only ran intermittently on regular switch positions. I solved it by bypassing the boost micro switch. The beater now only runs on the regular speeds but that's fine by me.
Nov 10, 2008 | Black & Decker MX50 PowerPro® Mixer
Here is where you can download the repair manual. Read the section on speed control adjustments and repair. This might not be difficult for someone who is mechanixcally and electrically knowledgible.
Mike H.
Feb 07, 2008 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
24 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
