Question about Canon PIXMA MP780 All-In-One InkJet Printer
Need to know how to get it back on line
Am not sure how to plug it in to connect with computer
  • Canon Master
  • 12,061 Answers
Http://www.retrevo.com/support/Canon-MP780-Multifunction-Printers-manual/id/259bh643/t/2/
Please go to the address above, and download your user manual, it shows you how with pictures.
Posted on Jul 14, 2010
Bought turtle beach z11 headset, cant get mic to work
The Z11 has a four-pole input/output plug to connect the mic and the earphone. The earphone needs to be connected to the earphone jack and the mic needs to be connected to the mic input jack on the back of the computer. In other words, you should have to 3.5 mm plugs. Plugging both into the same jack will disconnect one or the other. Check your adapter, It should have two separate 3.5mm plugs. If it does, be sure they are connected to the right jacks on the computer. The headphone jack will have a headphone symbol; the mic jack will have a microphone symbol. Go to System Preferences, Sound. Select the line in preference for input and the line out preference for headphones. Just may work.
Mar 14, 2014 | Apple iMac G5 Desktop
How do i check to make sure my usb printer is connected to a usb port c4200 printer
USB plug-ins (ports) are flat/small/rectangular openings and have half (if you look directly into the end of the plug-in) of the opening filled with a little flat (usually white) connector and the other half open to recieve the of themselves from the cord that plugs in.
Sep 30, 2010 | HP Photosmart C4280 Aio Printer
Battery wont recharge-
Below are some things to check for when charging your Sansa player:
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
To Remove the Battery... 1. Remove the back on the e200 by removing the 4 screws. 2. Lift off the back by using a finger nail or a small flat head screw driver. It will not take a lot of force to remove. NOTE: When replacing the e200 battery be sure that the contacts on the battery line up with the contacts on the player. 3. The battery has three gold contacts on one end of the battery, which is near the words SanDisk Sansa. Be sure these contacts match up with the three gold contacts on the back of the player. 4. Lightly push the lined up battery up against the contacts of the player until the bottom end of the battery can be pushed into place. 5. Replace the lid to the back of the player and then plug the player into the computer using the Sansa cable. 6. Once the player has connected to the computer and is ready to be used or says "Connected", unplug the device.
NOTE: If the device goes directly to a black screen after unplugging it, then the battery has been replaced incorrectly. Take the back off the player once again and flip the battery around and the e200 device should work properly.
May 31, 2010 | SanDisk Sansa e250 MP3 Player
A cable is not plugged into the network Adapter "Local Area onnection" where is the local area connection suppose to go?
This just means, that you don;t have a phone line, or a RJ45 line
plugged into the computer.
If you have a cable modem, then a line (rj45) runs from the modem
to the Ethernet port in the back of the computer.
You need to plug something in or us wireless to get on to the internet.
So it depends on what service you have depends on what you plug it.
If you need anymore help just post back, let us know what service you use.
Cable,phone, satellite.
Feb 14, 2010 | E-Machines eMachines Monitor E15T4
Hp problem
Try to make a new connection shortcut and make sure your telephone line is properly connected on your modem. Also make sure that your password and username is correct. another thing is check that your system date is correct.. Hope this works ! ITTech7574
Aug 28, 2009 | HP Pavilion a6863w-b PC Bundle with 23"...
Telephone line connection
Two options:
1) Pick up a phone line splitter (Radio Shack or just about any other retailer has them) that has a plug on one side and two jacks on the other. Plug this into the phone jack where the line to your computer is connected. Plug the cord to the computer back into one jack on the splitter and plug the line to the fax machine into the other jack. (If it will physically fit into the space on the back of the computer, you can just plug the splitter into the modem connector, plug the line cord into one jack and the fax cord into the other.)
2) (Useful if the phone jack is behind furniture or just hard to get at.) Get a phone line splitter with all jacks (two on one side, on on the other). Unplug the line cord from the computer and plug it into the single jack on one side of the splitter. Then run a new line cord from one of the two jacks on the other side back to your computer. Plug the cord to the fax machine into the other jack.
Jan 27, 2009 | Dell A940 All-In-One InkJet Printer
Cant connect to the internet
red light means moden is out of sync with the isp. Power cycle. by unpluging the power from the back of yoru modem, unplug Your router and also turn off your computer. Turn on your modem frist wait until all lights are green>If they dont turn green. CHeck your cables. make sure telephone line is plugged into it or cable line. . There should be a cable pluged in from your modem to your wan port. Then from your router to your computer. Is this a wired or wireless connection. If its a wireless connection i need to know what what os your using. so i can help you set it up.
Feb 05, 2008 | Arris WR850G Router (DHWR850G)
No Dial Tone on phones or modem
if you have a dial tone when your computer is not plugged in, then the problem ls with your computer[ a possible short in the computer] the phone cord to the jack, or anything in between such as a dsl modem.if you have dsl, be sure your ethernet cord [ that's the wider plug cord] is in the wider jack in back of the computer. it wont fit in the regular phone jack.if you have dial up, be sure the phone cord is in the regular jack not the ethernet port.[if you have one]
good luck
wg
Jan 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
How do I connect the wires for faxing?
there are two phone jacks at the back of the printer one is for line another one is for external device such as answering machine make sure you connect your phone line to the line jack at the back of the printer and try it should work. and also try to fax the right no.
Dec 12, 2007 | Lexmark X6170 All-In-One InkJet Printer
Plugging it in
Your Nortel M7208 phone is plugged into your Norstar phone system (not the phone line) You would not be able to use DSL on the same phone port used by the M7208 phone. A filter connected to that port would not solve a DSL issue and could only cause problems with the M7208 phone. You may need to put the filter on the phone lines before they connect to the Nortel phone system... I don't know which system you have or how it is wired up so I am not sure how easy that would be for you.
Nov 10, 2007 | NorStar M7208 Corded Phone
Canon PIXMA MP780 All-In-One InkJet Printer Logo
60 people viewed this question
old marine
old marine
