Question about Jenn-Air JCD2295HES Side by Side Refrigerator
Ice maker problem on a Jenn-Air JRSD224W
I have an twist tray jenn-air ice maker that I've replaced the tray resently and it I've noticed that the tray never fills up completly or the machine only make about six ice cube a cycle. We use a lot of ice and we constantly run out but if the tray would fill up as designed, we wouldn't have a problem. My question is, what can I do to increase the amount of water that goes into the tray at the filling cycle so that the tray fills to its proper level?
    Scholar:
  • 150 Answers
Check your water pressure if it is low then you are not going to get a good fill. you can adjust the fill on many icemakers look for an adjustment screw on the motor head
Posted on May 07, 2008
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
My Jenn Air refrigerator ice maker is dripping water out of the front right side (one drop at at a time) into the ice tray. The water causes the tray to freeze up into big clumps. Any suggestions on what...
Unplug water control valve for the ice maker side on rear of freezer. If water continues to flow replace the water control valve If you already tried that the bring me up to date on just what you have tried and how long this has been happening. Sea Breeze
Oct 25, 2009 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
171 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
