I have just fitted an fuji electricAWF18ui. the machine faulted within 10 minutes of first running. a technician was dispatched and said that the vacuum wasn't done for long enough and that moisture was in the system causing the machine to fault. he vacuumed an regassed and the machine worked for 3 days. the technician was recalled when the machine stopped working. he again re-gassed after vacuuming and the machine worked for 4 hours. the 3rd time he came he said the problem was still moisture in the system. i discconected the pipework like he instructed and used nitrogen to purge the system. i then vacuumed for 26 hours and re-filled with gas. the machine worked in cooling but when i switched to heating the mcahine outside run but the tubes got warm and then cooled. can you help
    Genius:
  • 1,665 Answers
It may be defective As your Quarranty has not expired better refer this problem to supplier.
Posted on Apr 20, 2008
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • Maanita Chadha
    Maanita Chadha Apr 20, 2008
    overall its a faulty equipment as it is requiring service every now and then and even after getting regassed for 2-3 times it is still giving a problem..i would suggest you to get it replaced
My Samsung washing machine has been put on and 2H appears on the screen
The error code 2H is not a standard Samsung error code.
You're going to need a on site technician that can access the machine's built-in diagnostic system to find the fault.
Sorry.
Have you unplug/turn off breaker to it for 10 minutes to see if it will do a hard reset? Do before calling tech.
Feb 25, 2018 | Samsung Washing Machines
WIL103 WAHING MACHINE
Try to power off you unit for about 5-10 minutes then plug it back in. Did the technician touch the control board?
Oct 22, 2008 | Indesit W 123 Front Load Washer
Unable to change channels on emerson flat screen despite new remote and new batteries. Saw description of removing housing and dusting off sensor
Sounds like remote control fault. Intensity of infra-red emission from the remote control is weak. Change the remote control or replace the infra-red LED inside it. Contact any service technician.
Nov 04, 2015 | Emerson Televison & Video
Nissan quest dies after running for 20 minutes
The engine and the automatic transmission in this vehicle are computer controlled and in most cases when a fault occurs a fault code is stored in the memory of the computer control module. There are exception to this, such as the Mass Airflow Meter and fuel pressure problems. What must be done is to have all the basic testing done such as a scan of the system for fault codes as well as a check with a live data scanner tool for engine functions that are not within range of normal, a trained technician is required to know what is correct and what isn't, then based on careful diagnostics done from a factory repair manual the correct part is replaced or the wiring repaired or the computer replaced (known as the PCM), which is very rarely the problem. Other basic checks must be done as well such as mechanical problems with the engine as well as engine state of tune and mileage on the engine. The transmission can have mechanical issues as well such as no gear engagement at all or a failed pump or other pressure related problems.
Sep 28, 2012 | Nissan Quest Cars & Trucks
Can't find tube to fit my back tire - stem doesn't seem to fit properly.
You have not explained in what way the valve does not fit, but this may help: Presta VS Schrader Bike Valves Explained It's very possible that you accidentally punctured the tube when installing it, especially if you used a tool to do so.
I would suggest you get some in-person help - bike shop, bike co-op or friend who's into bikes.
Jul 24, 2017 | Fuji Bicycles Crosstown
My kyocera FS1118 MFP displays C6400 error. Can you help me?
C6400 indicates that the engine board is not recieving the correct signal.
I would suggest that you turn off the machine and ensure that the cable that runs from the document feeder at the top rear of the machine into the connector on the rear of the machine (if fitted) is securly tightened.
You can also try turning the machine off at the wall for 10 minutes.
If this fails you will need to call out a technician.
Jul 21, 2011 | Kyocera FS-1118MFP Laser Printer
My Westinghouse TV shuts off when I'm watching after about 15 minutes. Turn off then on and runs maybe 20 minutes then shut off.
This sounds like a power board failure. Try calling your manufacturer and ask them if the TV is still under warranty. If it is have them dispatch a technician to repair the problem. If not, you are better off replacing the TV as the repair cost would exceed it's worth.
Feb 28, 2011 | Westinghouse 32" Flat Panel LCD HDTV
After a few minute on machine "user not detected on belt hit ok to continue " comes up on machine and shuts down if you don't hit ok within 10 seconds.
this is because the sensor or Smart Stop Circuit board is in the bar (ERGO BAR Handrail) is damaged or does not detect the user really maybe it´s dirty must replace
Sep 14, 2010 | Life Fitness 95Te Treadmill 95 Te
Year old front loading ge washer door won't open after washing towels. i can't find manuel or model number on machine, but what it does say on machine is: GE 10 cycle/super capacity plus/ 4 wash spin...
Love this service. Your technician, Lee was right on it and solved the problem quickly and efficiently. Within 15 minutes my washer was up and running again. He even suggested additional things I might do to keep the problem from occuring again. Rather than the expense of a repair person coming to my home, Lee affordably solved the problem. I will use your service again. Thanks.
Jan 27, 2010 | GE Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
