Question about Sony VAIO Notebook
My Sony laptop colors changed. The white area of
My Sony laptop colors changed. The white area of my screen has turned a light blue. Is my video card going bad?
  • 77 Answers
May be the problem with your vedio card setting or vedio card and sometimes it happend with your display screen also.
Posted on Jul 14, 2010
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
Display loses color after start up turning black & white
I wouldn't think that was the problem I would check the settings.
Mar 17, 2014 | HP G60-120US Laptop
How would the pattern on the screen change if a pure blue screen were substituted for the white screen?
What can you do if the laptop LCD screen turned completely white? 1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard). Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop. In some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful. Always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 31, 2013 | Computers & Internet
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dell inspiron 8500 laptop screen goes white
hello, when the screen changes colors or stays in one color it is mostly cause of a video card problem. Does this happens only when overheated, then maybe you can blow the cpu-video card heatsink and use a base with a fan to avoid overheating. If the screen is white all the time then maybe only a 2nd monitor will help understand if this is a problem of the video card or the screen.
Sep 18, 2011 | Dell Inspiron 8500 Notebook
I have a HP pavillion dv6 that I've had for about a year and just today while working online the screen suddenly changed colors. It's not inverted but some black colors are a solid red, some whites have...
ASAP (and the caps are intentional) get your laptop connected to an external monitor. If the display is fine on the "big screen", it's most likely you only have a screen inverter/lcd failure. Failing Inverters can cause the effect you're seeing as well as an LCD burn out on the way.
If the displays are identical, then your video card is about to fail.
At least you'll know, and know right away.
Best Regards,
Marcus (laptop specialist)
Sep 27, 2010 | HP 510 Notebook
Laptop screen and external screen have lost color completely, only getting black and white
In my opinion if you have black and white screen internal and external screen while booting and while you are into windows desktop you have a faulty graphic card. Common fault on toshiba laptops.
Actualy the reason for their sales drops dramaticaly in the past few years ;)
Feb 02, 2010 | Toshiba QOSMIO F15-AV201 Notebook
Light blue color to the screen
It's possible that the screen is going, it's also possible that the inverter is going. An inverter can cause the same color change problem. It's definitely one of the two.
Jun 09, 2008 | IBM ThinkPad T21 2648 Notebook
Sony VAIO Notebook Logo
281 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
