Question about Alfa Romeo Spyder Green 1:18 Diecast Model
How do you replace the tail light bulb: brakes light.
  • 31 Answers
Turn it aroud till comes out
Posted on Jul 14, 2010
1999 Dodge Ram 1500 - Right rear tail light won't burn for tail lights alone, but will still blink for turn signal and light up for brakes. Bulb was replaced with no effect. Left still works.
The bulb has two filaments; one for brakes and turn signal, the other for tail lights. One filament is probably burned out. Replace the bulb with a new one
Aug 09, 2017 | Dodge Cars & Trucks
My tail light doesn't work on the driver side only. Turning and brake lights work fine just not the tail light. What do I do??!!
Did you check the taillight bulb? Likely is is the same as the brake light. If the wire inside does not connect the two wire prongs the bulb needs to be replaced.
May 02, 2015 | Cars & Trucks
Change out a taillight
You want to change the tail light bulb?
The process for replacing tail light bulbs is the same in all models. If you have a burnt-out tail light bulb, you may need to replace the brake light, the reverse light or the turn signal. The procedure to replace each of the bulbs is the same.
    Instructions
    1. Open the Hummer's rear swing gate. This will expose the edge of the vehicle's tail light assembly. You'll see two small Phillips head screws that hold the tail light assembly in place. Put on your gloves.
    2. Remove the two screws from the tail light assembly. Pull the tail light out and inspect the back for two bulbs. The top bulb is the brake light and turn signal. The bottom bulb is the reverse bulb. Determine which bulb you need to replace.
    3Rotate the bulb's socket counterclockwise to disconnect it. Unplug the bulb from its socket.
    4Push the replacement bulb into its socket firmly. Insert the socket back into the tail light. Turn it clockwise to secure it in place.
    5Place the tail light into its cradle. Hold it with one hand and replace the Phillips head screws with the other.
Dec 03, 2010 | 2008 Hummer H3
Where is the fuse for the right side tail light?
hi if it is only the one bulb not working/tail light and the front light on same side is working along with number plate and other tail lights may i suggest you replace/check the bulb on defective light as if fuse had blown ? the front light on same side would not be working if you put ignition on and press brake your brake light shoul work ? if so change the bulb as the bulb has two elements inside tail light and a higher wattage element for brake light
Feb 25, 2010 | 2004 Honda Accord
Brake lights on tail don't work, upper one does.
There is a recall on the tail lights from GM. The problem I found on mine were faulty contacts that would burn out the bulb contacts in short order after replacing the bulbs. So even if you replace the bulbs they will only work for a short while before they burn out. Take it to a GM dealer to get the complete tail light assemblies replaced.
May 11, 2009 | 2002 Chevrolet TrailBlazer
Brake lights will not come on. It is not the bulb. The tail lights work.
The tail lights working would not necessarily mean that the brake light bulbs are good. If they are the type that have a double filament (ie: one filament for the tail light and another filament for the brake light ) the brake light filament could be bad and the tail lights still would work. If they are either single filament type bulbs or double filament type, I would check the bulb, fuses, and contact switch on the brake pedal.
May 10, 2009 | 2003 Chevrolet Suburban 1500
Right brake light out; tail light works fine
most rear tail lights and turn/stop lights are the same dual filiment bulb. it is possible for your tail light to work and your brake light not to and still have a bad bulb. I would check the bulb first, your brake light works on the left yes? this would mean that the fuse is fine
Mar 31, 2009 | 2006 Dodge Stratus
Hyandia Accent
not sure which top tail light you mean? do you wish to replace bulb or actual lamp on the rear screen? this is the high level brake light ! OR do you wish to replace bulb in one of the rear tail lamps offside/nearside ? which ever ? the h/level brake light bulb is accessable for bulb from the rear panel on hatch behind lamp bulb is 16 watt capless push in type
Nov 10, 2008 | 2003 Hyundai Accent
Alfa Romeo Spyder Green 1:18 Diecast Model Logo
62 people viewed this question
Top Alfa Toys Experts
ray gallant
Are you an Alfa Toy Expert? Answer questions, earn points and help others
