Question about Marshall MG100HDFX 100-Watt Amplifier Head
I was playing through my Jvm410 it was sounding great then the volume got quieter then no sound all lights work whats the problem power tubes maybe?
  • Marshall Master
  • 5,603 Answers
Yes, you MAY have destroyed the output tubes...
When replacing, make sure your MATCHED pairs go into V1 and V4 and the other into V2 and V3 respectively. Many don't realize the proper placement of matched pairs.
Open unit and if you find the tubes with the plates glowing red OR purple haze down between the elements, the tubes are gonzo.
Check the bias at connector CON1, Between pin 1 and 2 is a 1 ohm resistor in the cathode of the V1 and V2 side. Adjust the Bias1 for the number of milivolts matching the required bias current for two of the output tubes. Do the same for pins 2 and 3 of CON1 for the second side using the BIAS2 control. Fir your amp, you will want each of these set to 70millivolts.
It is possible (hopefully) that one of the smaller tubes burned out. These are much less expensive. EACH of these will have TWO points of light visible when they are operating. If you only see one, then 1/2 may be burned out. When turbes burn out, they cool down and sound will fade out.
There are other components that could cause your problem but those are not DIY unless you are adept at electronics.
Posted on Jul 14, 2010
Mpc 1000 loud static
Maybe try adjusting the MASTER level?
Good Luck
Other settings
Adjusting the master level You can adjust the level of the headphone and the stereo out by turning the MAIN VOLUME knob. The MAIN
VOLUME changes the analog signal level. This will also adjust the entire level of the MPC1000 digitally.
01. Press the [MODE] key and then the [PAD 10] (OTHER).
It switches to the OTHER mode.
02. Press the [F1] (GLOBAL) key.
The GLOBAL page will be displayed.
03. In the Master level field, set the level.
You will set the digital signal level, which will be sent out to the DA converter. The MPC1000 can output up to
32 sounds simultaneously. There is the great difference in the level when you play single sample and play 32
sounds. If you increase the value in the Mater level field, you can increase the entire level of the MPC1000 to
create more powerful sound with less noise. However, if you playback many sounds at the same time, the
level may be overloaded, which may cause distortion. If you decrease the value in the Master level field, you
can prevent distortion when you play many sounds at the same time. However, you cannot have a good
result in respect to the noise or punch of the sound. Set the appropriate value in the Master level field
depending on the application.
Mar 31, 2014 | Akai Mpc1000 Music Production Center
Hello, I own a hotrod deluxe. I take great care for it and never move it. Normally on the clean channel, the volume is regulated by the volume and the master. Today the amp sounded only half as loud as...
Do you turn on standby every time and wait for the tubes to heat up first? If you don't, it can severely damage the tubes.
But a common cause of this could be just old tubes. Like any other piece of technology, tubes get old. If you like to play your amp LOUD then they wear out a lot quicker. You have to replace tubes every now and then. Because I'm not there to check out your amp, I can't give you an exact answer but it sounds like that's the problem. This isn't always a bad thing. You can make the sound of your amp exponentially better with nicer, new tubes. Your amp has 12AX7 tubes. Very common tubes to use actually. I'm not sure what kind of music you play, I'm assuming mostly rock and blues. But here is a list of tubes and reviews on them.
http://thetubestore.com/12ax7review.html
This is how to replace a tube:
http://www.ehow.com/video_4438285_change-pre_amp-tubes-guitar-amps.html
Upkeep on a tube amp:
http://www.ehow.com/video_4438295_replace-tubes-guitar-amp.html
A note he doesn't make in the video is to dust out your amp. I use the compressed dust spray for the inside of computers.
So overall, stop turning up your amp to 11, make sure it's well ventilated and dust it out from time to time. Hope this helped.
Jun 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Google: Randall Padilla, that's me.
What could be an issue is if the cabinet is a 4 ohm cabinet and you plug it into the 8 ohm output. of the RT100 ... IT WILL BE LOUDER that way... for a LITTLE while... till the power tubes get gassy from overheating and the sound will GO AWAY. VERIFY the impedance of the cabinet and plug into the correct jack on the RT100. Every RT100 will do this... it is GROSS abuse of the amp if you plug 4 ohm speakers into the 8 ohm jack. Some of the power tubes may conduct so heavily when they get gassy that they will cause a hum before total failure. The tubes will first get red, then orange plates and that drives metal ions out of the plates, then they get a purple glow and eventually blow the fuse or something in the power supply.
May 07, 2011 | Randall RT Series RT100H 100W Tube Guitar...
I have a Kustom HV 100 hybrid tube amp. When I power it up, It will play normal for about 5 seconds and then the volume drops off. The preamp tube is only about 2 months old and this amp only gets played...
After the volume drops off, let the unit sit idle for a minute and then try it again. If the volume has restored for another brief period, suspect the filter caps are weak and voltage drops when you start driving the unit. In any case you need to have it serviced. Unless you can see the heater in a tube going out with vibration this may not be a DIY repair. If you see purple glow in a tube, replace it.
Apr 04, 2011 | Kustom Double Barrel 30-watt 2x12 Hybrid...
After playing for a while, approx 15 min, the volume dies away leaving some sound but greatly reduced. It then gradually returns to normal volume after about 3 mins. Otherwise all other functions seem to...
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Mar 29, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
I have an intermittent trouble with my Laney LV 100, intermittent crackling sound in sequence with the power light getting dimmer. this usually happen with high volume playing in chords. To describe more,...
clean all "vr" (variable resistors) like volume bass treb etc, sounds like bad contacts. this happens due time while they oxidating. maybe helps. use "contact" spray for best result
Feb 27, 2011 | Laney LV100 65 Watt 1X12 Guitar Combo
I bought a 1960 bugera head for 100 dollars that I knew was inop. Before I take it to a tech does anyone know what might be wrong? The fuse is good, and the power tubes light up, the amp turns on but no...
Tubes lighting does NOT mean they are working... AND some have two heaters because they are two tubes in one... so you have to verify the small ones have two heaters working... that is a starting point. Next tests involve a bit of electronics test equipment, namely a multimeter to check the poower supply is working. There are lethal voltages in this unit so find someone with experience to do these checks for you.
Jan 30, 2011 | Behringer Bugera 1960 Classic 150-Watt...
My 410 deville's channel switching doent work and is stuck on the clean channel. This really isn't a problem as I always use the clean channel and I only mention this in the event it helps diagnose the...
You may have a switch that may be bad. For the sound level high and low may need new tubes or possibly may not be seated fully into position. These tubes due get quite hot and do get loose over a period of time.Hope this helps.
Nov 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Line 6 spider 210 volume problem
The bypass switch in the headphone jack is likely broken. NEVER unplug the headphones while the amp is on.
There are certain small amps that have a possibilty of popping the power amp due to a feedback arrangement. Likewise, never use the headphone jack for ANYTHING other than headphones.
Dec 20, 2009 | Music
Guitar amp no sound or lighting
Ah yes: complete catastrophe. Usually when everything is not working, it is a single reason and when that single reason is fixed, so is the amp.
Based on what you tell me, I am going to say you have a bad power tube. And I will even go as far to say that you buy a set of tubes and play on them as long as you can. If so, then you not only burned up the tube, but weakened the power section and may have a slooow tube frier. I always tell customers: modern tubes have an effective life of less that 1200 or so hours and that varies. Replace the tubes once per year if you gig with the amp: period. Otherwise, guys like me (doing repairs) stay busy and the tube companies get rich selling tubes to amps with weakened power sections.
It sounds like you burned a power tube and blew a fuse. First, you need a new set of power tubes and some extra fuses (go to Radio Shack and set the value you need in SLOW BLOW fuses).
Then, replace all the power tubes. Don't worry about biasing yet, we are just seeing if there is a problem. Next, replace the fuse.
Turn on the amp and play on it at various volumes and settings. If all is well, take the amp to a tech and get it rebiased. If you can afford it, pay to have the grid/plate and other resistors changed so the power section will be like new (clean slate with new tubes). Your amp will love you for it.
Almost all of the amps I have worked on for performance problems (cant keep tubes to stay alive for very long) are directly related to end user use. When you use a tube until it blows it ALWAYS TAKES SOMETHING WITH THE TUBE WHEN IT GOES (like the power section components). The compents will be weakened and the tubes will 'wear' at different rates that can even move them out of the 20% tolerence they must be within to sound good. 99% of the time a board repair with a retube after a catastrophe fixes the amp until the next time it is 'run into the ground'. Tube amps are NOT invinceble: they are weak compared to solid state and expensive to own. But we love tubes because they sound great. I have solid state to knock around on, when when it counts, I play only with tubes. I have spent hundreds on good tubes because you do get what you pay for.
Hope this helps!
-mike
Mar 14, 2009 | Music
Marshall MG100HDFX 100-Watt Amplifier Head Logo
414 people viewed this question
Top Marshall Music Experts
matt martin
matt martin
Jim Goldsmith
Jim Goldsmith
freddybrass
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
