Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Steamer does not give out steam. The light comes one and you can pump it and steam comes out and then it will not give out anymore steam.
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
zzc
Posted on Sep 24, 2010
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
My Shark steamer works fine for a few minutes and then the steam doesn't come out anymore.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Dec 07, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Lights on but no steam and getting hot
In order to produce steam, you have to "pump" the steamer. After it heats up, pump it while moving it back and forth on the floor while mopping - it takes a few strokes to get the steam really rolling. I love mine - ;)
Aug 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Does not give steam.
Actually there was no category for clothes steamer, and before entering information I was prompted to pick a category so I chose vacuums hoping that when my problem was diagnosed it would be understood that the problem is a clothes steamer that has stopped giving off steam. Please help if you can. I appreciated your time.
May 20, 2009 | Westinghouse Vacuums
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
No steam in scunci steamer will not work lights uop hear pressure and heats up
no steam in scunci steamer, it does gets warm but no steam at all. like if it was blocked
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
208 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
