My biggest problem is i dont know where to find the thermostat on the egine. Where is it located and whats the best way to change it?
    Problem Solver:
  • 5 Answers
Follow the big hose from the radiator it goes to the thermostat housing
Posted on Jul 14, 2010
Were is the nuetral safety switch located on 2007 saturn aura xr egine 3.6
On the outside of the transmission or inside of it . How do you know it needs replacing ? Did you test or guessing ? Vehicle won't start in park but moving to neutral it does start ?
Which transmission does it have ?
Automatic Transaxle - 4T45-E
Automatic Transmission - 6T70/6T75
Dec 26, 2017 | Saturn Cars & Trucks
My 2007 sea ray mercury smart craft is not getting communicateon from the engine how do I fix that?
with water craft , the biggest problem is incorrect wiring used in the communication harness
the insulation allows water egress onto the copper which corrodes inside the insulation and causes failures
run continuity checks from the engine plugs to the instruments to check for resistance from corrosion check pins in connections for rot
May 10, 2017 | Mercury Cars & Trucks
Egine overheats
You did not mention the Thermostat which controls the temperature of the engine. Did you mean the Thermostat when you said temp sensor? If not, then change the thermostat.
Mar 05, 2015 | 2003 Chevrolet Impala
How do I locate and change the thermostat on 3ltr tdi 2009 ranger
I dont no alot about this car but in my exspearence its normaly where you have been looking,but you could see if its nexst to the water pump,best of luck.(maybe the firmostate was missing to begin with)
Dec 13, 2014 | 2009 Ford Ranger - XLT - In-Channel Rain...
2001 yamaha roadstar 1600cc is dumping to much oil back into oil reservaior after oil change always showing over filled leaving no oil left in egine, also making egine values tap and sounds like egine
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Changing your oil is easy
DIY Oil Change Yamaha Roadstar
Yamaha XV16AL Service Manual
OEM parts for Yamaha
YAMAHA XV1600A Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 15, 2012 | 2002 Yamaha XV 1600 Wild Star
2005 buick rendezvous thermostat
here is a pic of the thermostat housing in case you dont know what it looks like. its a very easy part to change although sometimes they are hard to get to. just make sure you do not put the thermostat in backwards the coil on the thermostat should go towards the hot side (coolant coming from the engine)
Nov 19, 2011 | 2005 Buick Rendezvous
Where can i find the thermostat on 1997 volkwagen jetta
Hello. I don't have your type of car; however, I can help you with youyr question because all thermostats are located in basically the same location. What you need to do is look for the upper radiator hose and follw that hose back to the engine block. Where the hose ends is the egine block, thermostat inlet pipe. The thermostat is located inside of this inlet pipe. There should be two bolts on this inlet pipe. Remove these two bolts and it should be there. Replace the thermostat and reinstall the inlet pipe. It is avery easy fix.
Jan 09, 2011 | Volkswagen Jetta Cars & Trucks
OVERHEATING, CAN i CHANGE MY OWN THERMOSTAT?
yeah its not super hard locate wether the thermostat is at the end of the top hose or bottom hose then remove the two or three bolts holdin the housing on replace the thermostat and the gasket dont over tighten the bolts when outtin the houseing back on it will crack the houseing.coolant will leak out if u dont drain sum before u remove the thermostat housing.hope that helps if u need more info let me know
Apr 20, 2009 | Hyundai Elantra Cars & Trucks
I need to change the thermostat on a 1997 buick skylark 2.4
water pump is located at the very back of your car engine almost touching the firewall.
its a pain to get back there and just pray your water pump dont actually go out cause its best to take to a mechanic its all inter twined with the timing chain and alot of removal just to take out and replace..best of luck
Nov 14, 2008 | 1997 Buick Skylark
Overheating
there are three hoses leading to the water pump. the biggest one oviously goes to the thermostat housing, but the other two are much smaller 1 inch hoses, one of wich goes on the water pump and the other on the thermostat housing. if you follow the hoses one will connect to the upper part of the overflow for the radiator after hitting a T in the lines, that hose connects to the thermostat housing, and the other goes to the water pump its self.
Jul 23, 2008 | 1989 Jeep Cherokee
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
