Question about Lanzar (MAXP154D) 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker
How to install a lanzar maxp154d dual voice coil
  • 19,396 Answers
Recommended enclosure for maxp154d
Send me the type and model of vehicle it is going into. From there we can determine what type of sub box to build.
Jan 31, 2012 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Will it get so loud my car falls apart eventually
The car falling apart is a NO. But if you want a lot of Boomy Bass, then make sure to make a ported box for your sub woofer and give it the power it needs. If i knew the exact model i would tell you the size of box and amount of power you would need to amplify it. dreamsystems
Feb 10, 2011 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
There are 4 connectors on each side of the speaker, how do i wire it so i can put the sub in the box so i can connect it to my amp?
There are 4 connectors on each side of the Problem with the Lanzar 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker. how do i wire it so i can put the sub in the box so i can connect it to my amp?
Dec 24, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
How do you bridge a dual voice coil
use a decent wire (same gauge as you would use to connect it to your amp) and connect it between the "+" pole of one coil and the "-" pole of the other coil. use the 2 other poles to connect the speaker to the amp. Have a nice day!
Dec 14, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
How to wire lanzar opti1532d dual voice coil 2 ohm
Do you have just one???? If so and your amp can handle a 1 ohm load, hook one voice coil to the other (positive to positive, neg to neg) then bridge it to the amp...If not you will have to take the positive of one voice coil and the negative of the other and bridge it to your amp....The other hot of one voice coil and neg of the other needs hooked together (jumperwire). That will give you a 4 ohm load.
Nov 14, 2010 | Lanzar OPTI1532D Car Subwoofer
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
How do you wire up a dual voice coil lanzar 15 for 4 ohm?
Hello dexterchapma,
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
Hope this helps.
Jun 27, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Lanzar (MAXP154D) 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker Logo
540 people viewed this question
Top Lanzar Car Audio & Video Experts
Morne Olivier
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
