Question about Brother IntelliFax-1860C All-In-One InkJet Printer
Error message regarding new ink cartridge
I have today installed a new Brothers 1860c all-in-one printer. When I try to put the new ink cartridge in, the machine tells me that there is no cartridge and to reinstall (or install cyan--which I've done). I have done this 10 times and get the same messahe. What is the fix?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
The cartridge is not put in good. make sure the tab that the ink came with is put in good then make sure the cartridge is clicked in all the way till the end. Then do a cleaning and a test run. Then you should be fine. If this does not solve your problem post to me and i will instruct you futher
Please rate me good
Posted on Jul 14, 2010
THINKS IT NEEDS An ink CARTRIDGE
probably needs to be an OEM dell cartridge . they have put chips in them now so we consumers have to spend more for them
Oct 10, 2017 | Dell 926 All-In-One InkJet Printer
TURNED ON THE PRINTER---UP CAME ( CARTRIDGE
please put on the printer, open the lid, the ink tray will slide out, kindly replace as you remove, and ensure you have the recommended inks,
regards
Apr 27, 2010 | HP Officejet 5610 All-In-One InkJet...
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 06, 2009 | Dell A940 All-In-One InkJet Printer
Not Receiving Faxes
If it is a fresh ink and all carts have ink, you can unplug the machine and plug it back in while you hold the stop button for a few seconds after it powers up.That usually clears the error.
Nov 04, 2009 | Brother IntelliFax-1860C All-In-One InkJet...
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error message no cartridges
The plastic tips ( projections ) under the cartridge are brocken. Chech them and see if that is the case.
Best regards:
jnph_2001
Mar 22, 2009 | HP DeskJet 5150 InkJet Printer
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
color cartridge.
Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Ink
If you don't have the cartridges seated properly you will get this message. Pull them and try again. Myself, I tried to save some money, and bought Brothers refilled ink cartridges. They wouldn't work, so only use new Brothers ink cartridges. Unplug the printer from the wall for it to recycle, don't use the power button. Good Luck
Apr 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother IntelliFax-1860C All-In-One InkJet Printer Logo
159 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
