Question about RCA P52960 52" Rear Projection Television
What is the liquid in the lens of a rear projection
Tv was tilted when moved, lost video when plugged in, has sound and luminance but no picture.
Posted on Aug 01, 2010
  • RCA Master
  • 8,617 Answers
Thats the CRT coolant.
Posted on Jul 14, 2010
Liquid coolant in big screen tv, what is it?
It is a very toxic material called Glycol==if touched it gets absorbed into your body by contact--there to keep the picture tubes cool.
Lens should never be taken apart---if it got on the circuit boards it will short things out and start dissolving leads and the actual board as well.
Jun 15, 2012 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi rear projection tv is too dark to see picture
This is a very common problem within your projection TV set there is a small red, green, and blue picture tube. On top of the tube there is a lens that focuses the video on the screen. Between the lens and the top of the tube there is a hollow chamber filled with a clear liquid. This fluid is specifically designed to keep the tube from overheating. After about 4-5 years the fluid will start to become cloudy and will will get worse over time. Tvrepairkits.com is a good place to get a repair kit to fix this condition yourself.
Dec 19, 2011 | Mitsubishi WD-62525 62" Rear Projection...
GE 46GW947 TV. Screen is yellowed on top right corner with triangle shape a little less than full screen. Cleaned lenses and picture got clearer but still yellow on top right.
If you are able with the set on look into the three lens, what you are looking for is is there an visable liquid in any of the three lens on top?
These sets use a sealed area with Glycol, sometimes it leaks out so it is on top of the inside lens, DO NOT TRY TO REMOVE LENS COVER IF YOU SEE THIS.
SD TECH
Apr 13, 2011 | GE 46GW945 46" Rear Projection Television
What is the liquid in side the red orange and green lens.
it is lamp coolant fluid ethylene glycol and glycerin. its sorta like car antifreeze but have a thicker and clear. the one i get is # 1915-16sq
Feb 23, 2011 | Akai PT4799HD Rear Projection Television
I have a JVC rear projection TV. from the frot it looks like the green color is sagging. we took off the back panel & the green lens... it looks like there is liquid under the lens & that it is...
The tv pictures cloudy or hallow?Yes,than the R,G,B CRTS Tubes guns require changing it coolant liquid.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to used.But just R,B,G colors lines mis alignment,colors shadows or 3D pictures,this problems is a convergence problems,it dead.The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 11, 2010 | JVC AV-65WP84 65" Rear Projection...
How to make the picture to a Philips 2002 rear projectiontv clear
needs to replace the liquid in the tubes of blue and green projection
Jan 06, 2010 | Philips 55PW9363 55" Rear Projection...
Under the lens is a leaking. and the color is messed up.
The silicone liquid coolant is leaking, you can try looking here:
www.mcmelectronics.com
Nov 15, 2009 | Philips 60PP9202 60" Rear Projection...
Water looking droplets on inside of blue lens
droplits are more than likey air. sound like a glycol leak on the blue tube. look for liquid underneghth the tube. THis would require replacement of blue tube.
Dec 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
The screen has a yellow tint
I had a friend who had this problem and the repair shop replaced some liquid or gel that the lens shine through and afterwards the picture looked like new again.
Oct 22, 2008 | Zenith D52WLCD 52" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
