Question about Kenmore Dishwashers
Green clean light is flashing. and dishwasher willnot start.
    Genius:
  • 1,075 Answers
Ane of two things.1 door switch.2main circuit board switch.adrian,,,
Posted on Jul 14, 2010
SOURCE: the dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Posted on Apr 14, 2009
localwonder
  • 6784 Answers
SOURCE: clean light flashes and dishwasher wont start
HI, this is a dirty filter alert. it could also be a control fault as well. clean the filter and, disposal as well. if this alert cannot be cleared, replace the control board or, timer.
Posted on Jun 22, 2009
jsrock516
  • 5911 Answers
SOURCE: Green "Clean" light keeps flashing, dishwasher won't start
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 15, 2009
SOURCE: The green clean light is flashing and I can no
here should be the solution for you.
as of note, the part is cheaper here, also "New10" coupon gives 10% discount. It should be the correct part# for your dishwasher, but to make sure, send me the model number, I'll verify.
Posted on Oct 20, 2009
  • 949 Answers
SOURCE: The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
Posted on May 23, 2010
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
The dishwasher won't start, the clean light flashes green 7 times
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
try opening the door and closeing it to aknoldge you know they are clean and is there a lock symble under the green light
Feb 10, 2009 | Kenmore Dishwashers
Green light flashing, won't turn on
A blinking light, and possibly no lights, with the door closed may indicate faulty door switches (very common on newer models). Depending on the model, the switches can be removed, cleaned and put back
Jun 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
52 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
