Question about Sony DAV-BC150 System
My sony dvd home theatre system dav-bc150 is displaying an error code c3100 and making noises when in dvd mode. What should I do?
SOURCE: Sony DAV-BC150
Sounds like your TV's sound output isn't working. Check all the connections and if that doesn't do it, try hooking up some other sound system to the TV to check that it is working properly.
Posted on Aug 20, 2008
welcomejee
  • 10594 Answers
SOURCE: I have a sony DAV DZ230 home theatre system
Push Power Protect is error sign when unit got problem in Power Amplifier section.
Let me know if you have electronics repair experience to help you further as I have all necessary info and schematics of DAV-DZ230 home theater system.
Posted on Nov 24, 2008
welcomejee
  • 10594 Answers
SOURCE: why does push power protector keeps flashing in
This is an error massage and comes when home theater got some internal problem specially in amplifier output section that can have defective output IC etc.
It is not user level repair and requires qualified tech for fix.
Thanks.
Posted on Sep 14, 2009
SOURCE: sony DVD home theatre sytem Dav-fxg99k is
DAV-FXG99K shock
Posted on Nov 11, 2010
  • 569 Answers
SOURCE: Getting an error display as
Turn off your unit at the power button. Check speaker outputs for a short circuit - also check other end of speaker cables for a short. If you can't find an obvious problem then disconnect all speakers and power up the unit. If all is OK then connect speakers one at a time (this should be done with the unit powered OFF) and power up after each conection. This should identify which output is causing the problem.
If that does not work then it's an internal fault that will require a service engineer to identify - but I hope that is not the case!
Posted on Jan 21, 2011
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
Remote not working
i want to buy a remote control for sony dvd home theatre system dav-fxg9k, where i can get it?
Jan 11, 2014 | Sony SS-FXG9K Multi-System Region Free DVD...
Sony HCD-BC150 As soon as I turn it on, it shuts
Change the audio amplifier IC are on short circuit and that´s the cause your device goes to protect mode
Aug 11, 2009 | Sony DAV-BC150 System
How can I change the areal code of my DAV-BC150
Scroll through the menus to find an option titled “Region.” It may be hidden in a maze of sub-menus. Re-set region to Zero (0) If you can reset your region to Zero (0) your unit will read any DVD from anywhere.
Dec 12, 2008 | Sony DAV-BC150 System
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
C:13:71 error on my DAV IS10 SONY home theatre
I think it is a dvd laser failure My Sony HT gave that error when it couldnt read discs , its most likely a failed laser (DVD player in one of those home theatre in a box)
Oct 07, 2008 | Sony DAV-IS10 System
I have this same problem. Plays music CDs fine but DVDs do not work. It recognises the DVD tries 3 times to play it displaying "Reading" and then moves on to the next available disk. Any suggestions?
Mar 20, 2008 | Sony DAV-BC150 System
Sony DAV-BC150 System Logo
177 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
