Question about Dynex DXWEGRTR Router
My router won't come on could it be burned out
  • 176 Answers
If there are no led lights could be the router or power supply, or bad outlet..try a different outlet first. if not buy a router online its much cheaper than a retail store if you have the time to wait. you can also check out slickdeals.net and search for a router
Posted on Jul 14, 2010
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
Can't connect iphone to dlink router
When my ipod tries to connect to my computer wirelessly, it asks for the password. I enter it, but it won't accept password. It finds the router ok, just says password is incorrect. I've checked and it's the right one. Any suggestions?
Nov 27, 2011 | D-Link DIR-615 Wireless Router
My password won't work?...and it won't open...what would i do ??.the reset button also wodl'nt work?/
if the reset button wont work better to replace the router. But before replacing try the following steps first to reset your router.
Step 1: Plug the power of your router wait until the lights are fully initialized.
Step2 : Reset your router by pressing the reset button or hole with atleast 5-10secs.
Step3: Open a browser (ei, IE Mozilla or Google Chrome etc.) and type the specified IP address on the address bar.
Step4 Then type the username : Admin password : 1234 or leave it blank.
Hope it helps.
Sep 09, 2011 | Edimax BR-6226n nLite Wireless Broadband...
My old d-link router works fine. I bought a new DIR-615 but it won't connect. My computer won't "see" it. I followed all directions several times.
Make sure that the broadcast SSID in your router is enabled. Try setting it up again and make sure all necessary settings are set, or it might be the settings in your computer itself, let me know what type of computer you are currently using so i can check.
Jul 03, 2011 | D-Link DIR-615 Wireless Router
Pentair pool light fiber optic won't light:
check light generator on deck light probably burned out
Jun 14, 2011 | Pentair Pool & Spa
I have been using Nero Express V 6.0 on my newest computer [operating system Windows 7] for over a year, and suddenly it won't allow me to burn DVDs. Is this a driver problem? ... and if so, how can...
When you try to burn, how many steps in Nero Express work correctly.
What happens when you try to burn?
What error-message(s) do you get?
Does it seem to burn a disk, but the resulting disk is "empty" or "never-written-to" ?
Jun 11, 2011 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Dynex DXWEGRTR Router Logo
106 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
