Question about Whirlpool WFW8300SW
Whirlpool Duet Sport WFW8300SW04 frontload washer power comes on but once I press start it shuts off. All lights work but it won't start. Unplugged machine over night, nothing changed. No error codes. Service tech tried to run diagnostics but that will not work either. The washer is 1 1/2 years old.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Duet Washer Won't Start; Outlet Fine
How old are they & where did you get them from?
Jan 30, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How do i run a diagnostic on a Whirlpool Duet Sport WFW8300SW04 frontload washer
what code is it giving. there should be a paper under front bottom kick panel. that has all codes and sequences on it . or you can google code list . i think it was power button 3-5 sec then any cycle button 3-5 seconds 3 times
Mar 04, 2013 | Whirlpool WFW8300SW
Hi, I have model wfw8300sw04. I'm having trouble with it spining & draining. It won't drain and it spins once and stops. I have check the drain for any clogs and nothing.
Open the door and push the bottom front of the boot aside and look to see if an article of clothing as gotten in there. Post back your findings.
Nov 13, 2012 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Had to stop my whirlpool duet sport front load washer to add a garment, pressed pause, now it will not resume, is there a reset. i turned it off, unplugged, etc. has power but will not continue the cycle...
Try unplugging for 30 minutes, then try to start again. If this doesn't work you probably have a contol board or door lock problem. Good Luck, Appliance Specialists
Feb 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8300SW Logo
1,165 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
