Question about Brother Computers & Internet
I am trying to make these compatible do I need some sort of adapter or how do I make this happen. I tried to locate under adding printer but it did not show printer under network when I searched what should my printer be plugged into to make this work? Thanks
    Genius:
  • 1,040 Answers
Don't worry. you just have to install the driver for the same.... If you have already installed the driver then make sure that the PC and printer is in the same workgroup..... Still you are not able to fine the printer then in the web browser (of PC in which you wanna to install the network printer) type the ip address of the PC (to which printer is connected) then you will get some options in that one option is "printer", click on that....
Hope this has helped you... Thanks..
Posted on Jul 14, 2010
Testimonial: "Thank you but my laptop crashed before I could use this now I got Windows 7 and it seems a little more user friendly. "
Why cant I get my email on my tablet
Possibly your sort column got changed. Try sorting by date, descending.
Jan 28, 2015 | Eforcity 3.5mm Audio Adapter Compatible...
Dell 2155cn
You can make your printer WiFi compatible by connecting it to your wireless modem/router using the Ethernet port on the back of the printer, if the printer is located within a reasonable distance from the modem/router. The cost of an Ethernet cable (even a longer one) is probably less than the cost of the wireless adapter (I assume you have not bought the adapter yet).
To find out if the wireless adapter is compatible with your printer, you can call Dell technical support (for the printer or the adapter).
Hope this helps.
Jul 01, 2014 | Computers & Internet
Sometimes the pointer will not work,wait a minute and it works again
The mouse communicates using radio signals sort of like WIFI. The most likely source of problem is interference. If the mouse is using a plug in adapter, try moving the adapter closer to the mouse. This will improve signal strength and may solve the problem. You may need to get a USB extender cable to move the adapter closer. Depending on where you get it from, it may cost as much as a replacement mouse.
On thing you can try is using the mouse in a different location. e.g. if the problem is at home, what happens if you try to use it at work or school or vis versa.
Thanks, Jim
Mar 08, 2011 | HP Wireless Optical Mouse
The laptop lenovo z560 does not switch on. With battery it shows 2 short flashes of battery charge idicator, an one long (about 10 sec) and than nothing is happening. Withou battery nothing happens after...
Hi smialkovskyi,
With this specific concern that you do have, unable to turn on your Lenovo Z560, there 3 components that need to be checked. Your battery, the AC adapter (charger) and as well as the DC In port.
1.Based on what you have said, with the battery alone you have noticed that it's led indicator will show however still can't turn on system. Battery seems to be in good condition however no enough charge to turn on the system.
2. For your AC adapter, when you're using it without the battery nothing happens. To check if this is defective try using another AC adapter that is compatible to your unit. If your computer turned on using another AC adapter then your charger needs replacement. (You may also try using your charger to other unit where it is compatible, just to test).
3. However, if after doing the previous instruction and still system won't turn on then it could be the DC In port which is defective. This port is built in to *********** board.
After doing all these you need to contact Lenovo. They might be replacing your charger or *********** board if system is under warranty.
Hope this helps.
Thank you for using Fixya.
Jan 28, 2011 | Lifetime Lenovo/IBM IdeaPad Z560...
Hi! When I press power button, the front LED battery blinking for 5-6 times, then no longer happen. If I remove the battery pack, no one LED blink, no one LED light, nothing happens. The output voltage of...
Your battery pack is not charging. By removing the battery pack and trying to run on AC only you have proved the AC adapter is either not working or the power is not getting through to the laptop.
The best way to sort this is to try another adapter and see if the laptop works, if it does then your adapter is broken (this is possible even though it reads 19.1 under no load.)
If the laptop still does not work with another adapter then the laptop itself will heed repair.
Oct 31, 2009 | Acer Aspire 1640Z Notebook
Wireless printing
Make sure once you install the wireless printer on your computer that you go to your control panel. Once there make sure the wireless printer is set as the default printer. You can find this in the control panel under printers. Also make sure your printer that you are installing works with vista if not you will have to reinstall every time because vista won't save the data if it is not vista compatible.
Sep 27, 2009 | HP Pavilion dv6000z Notebook
Usb wireless adapter for Compaq Presario 5000
Most netgear adapters will work.
They're around £20 and will connect to pretty much everything =)
They work on windows, from 98 i think. So aslong as the old tower has a sort-of up to date OS then it'll connect for you :)
Hope it helps.
Ed
Mar 17, 2009 | Compaq Presario 5000 PC Desktop
Problem after I tried to run the file setup.exe
It seems your device is not compatible with 64 Bit operating systems, which you apparently have. If you are sure you do not have a 64 bit OS, then the driver may be faulty. You should be able to locate the driver at this site
If they do not list a 64-bit driver, you will need to try a different adepter.
Jan 04, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
My printer will print a test page but when i want to print from the internet or word nothing happens . I have checked if all is plugged in and it is, I have also just changed my ink cartaridge, can you...
You try can uninstalling the printers software on the computer, then install it again, you may need the original cd for the job.
you can also try adding a new printer under control panel anf set it as default printer.
Sep 11, 2008 | Computers & Internet
Adding bluetooth to toshiba laptop
Well,I'm not really an expert on Bluetooth, but let me try...
Which version of Windows are you running? If you have Windows XP SP2 or above, the Microsoft Bluetooth stack should be installed on your system. First make sure that the Kensington bluetooth adapter is compatible with the printer and the OS. From what I heard Canon sell a separate Bluetooth adapter for about $80 for this, but I'm not too sure.
Secondly, ensure that the built-in Bluetooth Stack or Software has the required Profile for your printer.
Next, put your printer in "discover" mode (see printer manual for more info ). Use the Bluetooth Connection Utility software that came with the built-in Bluetooth stack to "discover" the printer. Follow the instructions by the Bluetooth stack manufacturer on how to pair and connect Bluetooth devices to your built-in Bluetooth stack.
Please also see THIS article. although it is meant for the Logitech DeNovo keyboard, it can be used for any Bluetooth enabled devices. (Just replace the DeNovo wit your printer in the article.
But mainly, make sure that the Kensington adapter is compatible...
Hope that helps..
IrishDruid
May 04, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
Top Brother Computers & Internet Experts
edy copier
edy copier
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
