Question about Frigidaire PLRS267ZAB Side by Side Refrigerator
Water dispenser putting water through the ice maker
When we get water from the door, water is overflowing from the ice maker into the ice dispenser. I noticed water running out from around the ice dispenser after filling a glass. Opened the door and saw the area behind the ice dispenser door was filled with water and water was dripping from the ice maker. Held the door open but depressed the door open sensor and had someone run water in the door and water started flowing out of the ice tray. What do I need to clean or replace to fix this?
22yooper
  • 828 Answers
SOURCE: frigidaire water leaks
I suspect that when the water valve was replaced, that the plug's were reversed that provide the power to the valve. Exchange the two plugs on the water valve and you may find the problem is fixed.
Posted on May 26, 2008
docjohn174
  • 943 Answers
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Posted on Sep 11, 2008
SOURCE: drip tray full of water, don't know how to get it out to dump
Tough one. Remove the screws that hold the grill on the bottom front of the fridge. By lifting the electrical and water tubing up on the left, you can slide out the pan about six inches. Then use a turkey baster or something to remove the water. I haven't figured out how to remove the pan completely without taking out a lot of other stuff. Next try to determine why there is so much water in there. In theory, it should evaporate.
Posted on Nov 15, 2008
rpbuice
  • 161 Answers
SOURCE: Ice maker overflows
The Icemaker may not be dumping the cubes after they freeze then more water pours in on top of them. The icemaker has a heater which turns the cubes loose and allows them to dump. You may find someone to work on an icemaker, not sure. If this is the case, I would replace the icemaker.
Posted on Dec 16, 2008
SOURCE: Ice maker won't fill with water
replace selenoid valve
Posted on Aug 20, 2009
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Turn on water light on outside of door
Can be faulty control panel causing these.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 24, 2012 | Maytag Refrigerators
Ice dispenser flap
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 24, 2012 | General Electric PFSS6PKXSS Stainless...
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
These will help.
Thanks,.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
Why is green light flashing
Its indication of overfreezed fridge or freezer unit.Or any door not getting closed properly.
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Ice maker
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
My GE ice maker is overflowing. whenever I
you have anserered your owne ? yes its the dual valve as the are independent and one side is for foutain and other is for ice . and let in diferent amounts of water .. mm replace the water valve ..
Jul 04, 2010 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Hi, i have a kenmore elite side/side w/ice maker and water disp
take a blow dryer( nothing else) and put it on high.
you can have some trapped ice or even some food. get a flashlight and take a look. use tongs to remove anything!
Mar 18, 2009 | Refrigerators
Frigidaire PLRS267ZAB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
