Question about Citiwell International Orbitor 5500 Telescope
I assembled it without a manual because i cant find one, and i cant seem to work it everything looks good but with the lense i cant quite seem to work it, thanks- Sean Karim
  • 3,186 Answers
Put the eyepiece with the largest number written on it into the focuser. DO NOT use the 2x barlow if you have one.
Go outside during the day time and practice focusing on a distant object using the eyepiece mentioned above.
Line up the small finder scope with the main tube-- point the scope at the top of a distant telephone pole or church steeple.
Without moving the scope, line up the cross-hairs in the finder scope with the same object. Once this is lined up you can use the small finder scope to locate objects in the sky.
Read my TIPS on my profile page.
Posted on Jul 14, 2010
Hello, I just brought my sigma macro 105mm lens and Im having trouble getting it to work probably on my nikon d90, they only way I can get it to work is turn the aperture on the lens to f32 I cant change...
Turn the aperture ring to f/32 and leave it there. After that, forget the lens has an aperture ring at all. You can let the camera control the aperture in any mode except the M and A modes. In the M and A modes, you control the aperture by turning the command dial on the front of the camera, the same way you control the aperture on a lens without an aperture ring.
Mar 06, 2011 | Sigma Telephoto 105mm f/2.8 EX Macro...
When I look into both the finderscope and the telescope, everything is upside down. We can't figure out if it's assembled wrong or what???
That is just the nature of the beast with most telescopes. When there are two concave or positive lenses in play, the object being viewed appears upside down.
The ways around this are using one positive and one negative (convex) lenses or adding a third lenses. The options for a third is sometimes referred to as an erector eyepiece.
As it stands, if it's upside down, it's assembled correctly
Best regards
Mike
Nov 07, 2010 | Toys
The battery cavity in the trunk fills up with water. I have removed the battery and dried it out but there doesn't seem to be any drain holes to drain out any water collected in there. I found a small...
I think you should be looking for the water leak first ! The trunk rubber seals and the tail lamps are high on the suspected list. The drain hose you are looking at could be the fuel tank filler vent hose , necessary to stop vapor lock in the fuel system . Remove the trunk liner and replace with newspaper and check daily for water tracking daily . good luck
Apr 11, 2010 | 1997 BMW Z3 Roadster
I also bought one & have no idea how the lenses should work...
Verify that the mirrors are aligned; look through the eyepiece holder (without an eyepiece) and you should see the main mirror with your eye looking back from the center. Ensure that there are no filters on the eyepiece, and use the lowest power one to begin (longest focal length).
Sep 08, 2009 | Tasco Galaxsee 46114500 (500 x 114mm)...
My camera cant focus on anything
It seems as if the lens isn't installed properly, make sure it's screwed in right in its mount.
Tom
Jun 20, 2009 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
My sony camera displays Turn camera off and on again
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 09, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Camera is out of focus and i cant seem to chage it. it picture is so blurr that i cant even tell what it is poined at. it wasnt like this when i bought it. can you help?
Sorry, this service is quite stupid,
I`ll try.
Many cameras has a circle arround lense. While looking a picture try to rotate that cirle.
Best wishes!
Nikola
Mar 28, 2009 | Gear Head WC330I Webcam
I have five Casio EX-Z57 different parts: lense, LCD, etc., broke in each set.
you are correct, casio solders their backlight to the circuit board. If you look at my website: http://digitalcamerarepair.googlepages.com, I have a tutorial for the ex-s500/600, the lcd unit is similar, so you can get an idea of how to change it.
Jan 23, 2008 | Casio Exilim EX-Z57 Digital Camera
Broken?
If if won't focus manually then there is a problem with the helicoid and you'll need it professionally repaired. Don't force it.
Nov 04, 2007 | Sigma 30mm f/1.4 EX DC HSM for Sigma
Citiwell International Orbitor 5500 Telescope Logo
173 people viewed this question
Top Citiwell International Optics Experts
Marvin
Marvin
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you a Citiwell International Optic Expert? Answer questions, earn points and help others
