Question about Miele 18 in. G601SC Plus Slim-Line Free-Standing Dishwasher
My meile slim line is closing properly but the power will not switch on, any advice?
    Genius:
  • 1,075 Answers
Most likly cause door switch.adrian,,,
Posted on Jul 14, 2010
Took the doors off my furnace to check for cleaning, and now it does nothing. Not even a power light. What happened?
The service switch may not be closed properly. Remove the doors and look around the inside the perimeter of the areas where the panels go in, there should be at least one switch, maybe two. those switches have to be closed and are kept closed by the panels. Make sure they line up properly with the doors and that they are closed, otherwise the unit won't do anything. If the are engaging, and it still won't go, cut the power and test the switches.
Mar 08, 2015 | Heating & Cooling
Why is the GFCI outlet getting power, but still not working?
GFCI's have 4 terminals. 2 marked Load, 2 marked Line. The black and white wires from the power supply MUST be connected to the LINE terminals. The load terminals is where you connect the outgoing circuit (i.e. plug, light etc). Anything connected to the load terminals will be controlled by the GFCI, so when it trips everything on that circuit will go off until you rest it. The other light/switch cannot be connected to the GFI if you want the switch to control it separately.
Jul 18, 2014 | Leviton R71-N7599-0RI 15 Amp SmartLock Pro...
How to determine the postive and negitive wires for the Targus APV10US1 100W Slim Line Mobile Inverter 150Watt Power Supply
With colour coded wires, red is + and black is - . On the two pole connectors part the + is the inner one and - is the outer node surrounding it. If you're not sure take the connector off and check which wire goes where. Red is always +. Better yet, use a DC tester or make your own using a LED of sufficient current rating (12V in your case). With all diodes current only goes one way from + to -, so it'll emit light if it's connected properly and not, if it's not.
Apr 19, 2012 | Targus APV10US1 100W Slim Line Mobile...
Heater not working on Mr Slim
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.If it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 11, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Dryer will not dry clothes.
I assume it runs and this is from that stance. If it doesn't the motor has to be checked and the power coming in. In fact the dryer can run and still not have the correct power to opperate the heater.
Assuming you have a volt meter and know how to use it properly.
These are the steps that the power and machine have to take to operate properly
A. If the dryer has all of these things it has to be heating and an air flow problem (kinked or dirty dryer duck, motor fan clogged with lint, vent flapper not opening...) is suspect.
B. ELECTRICAL
1. power is correct (USA 220V across line and 115v to ground/neut) 2 hot lines with potential between them and a neutral and possible a ground
2 Door switch is closed
3 Timer switch closes and ready s power to heating element through centrifugal switch in the motor circuit after the motor is running.
4 the heating element is assumed to be good and have 220v at this point. Checking for voltage at the element will assure all before are ok and at least allowing the heater to work.
5 the heating element is controlled by 1 or more thermostats and a safety thermostat. If either of these switches do not close when the dryer is "cool" they are bad. NOTE some dryers could ahve 3 wire thermostats. These can read closed on one set and open on the other. And this is how they should be if good. But tracing the wire diagram will tell which set is closed and when.
6 if you have power, the timer contacts to the motor and the heater (separate circuits usually)are "closed", the motor runs, the cent switch "closes", the temperature operating thermostats are closed, and the heating element is good you have to have heat.
1 Check for 220V power into the dryer. If not check breakers and turn off and on several time pushing them firmly. If this is ok and 220V present step 1 is done.
2 This assumes the motor will run
Nov 01, 2010 | Whirlpool LER4634J Electric Dryer
MY SAMSUNG TV SWITCHES OFF BY IT SELF
Good day sir/maam, the swiching off thing can be caused by the setup of the sleep mode. check your remote and set the sleep mode to off.
It could also be a failure of the switching power supply board. This symptom needs to be checked by an authorized service service center, better call or visit your local dealer, for proper advice on your TV. Hope this helps.
Oct 13, 2009 | Samsung 61" Slim-Depth DLP HDTV
My samsung slim fit tv has a horizontal line which
hum bar. possibly related to power supply filtering. sometimes reversing the power plug will help. check cable connections for tight fit.
Sep 20, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Miele 18 in. G601SC Plus Slim-Line Free-Standing Dishwasher Logo
60 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
