Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Won't stay running when i take my foot off the brake pdl
20 hp 42" crftman won't stay running when i take my foot off the brake.the blades will engage but cut out in 3 -4 seconds.If i shove it into frwd or rvs it drives for 2-3 seconds and wants to shut off. then i immediatly depress the brake and it stays running.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
It is caused by the safety system - the seat switch, or the wires and connections going to it, cause this problem. Lift up the seat and look to see if the seat switch mounting has come loose or is broken. Make sure the connectors on the seat switch are on tight. If all that looks OK, take the seat switch out and use tape to keep the plunger pushed in. If that fixes it, then the switch mounting is the problem. If that doesn't fix it, then replace the seat switch itself - it's not expensive.
Posted on Jul 14, 2010
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
My blades stay engaged at all times model # 917273012
if the blades are staying engaged all the time try and unplug the switch if they still stay on you have a short also try getting off the seat that should shut them off as well shifting into reverse should shut them off as well if they stay on threw all that you have a shorted wire in the system
Jul 09, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
When i release the brake on my mower the engine dies if i push it back down immediately it will continue to run
Check your seat switch. If there is someone in the seat, the brake can be released and/or the blades can be engaged. If you can do neither, the seat switch is not opening.
Let us know,
Your Fixya Tech, Gary
Aug 15, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When I let the cluth brake out my engine shuts off
sound like 1 of your safety switches is bad. mower will run with the brake on and your not on it. there should be a seat switch under the seat, there should be a blade engage switch somewhere on the chassis, and there is also a brake switch. trace your wire harness through out the mower and check each switch. you can check the switches by unplugging them and connecting a wire to each terminal in the plug to check each 1. if after you unplug a switch and use the wire and the mower stays running after you release the brake then that switch is bad....you can bypass the switches by leaving the wire connected to the plug.
May 31, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 42" 19.5 briggs runs great , shuts off
check seat switch make sure it is plug in good you can unplug it and jump it with a jumper wire to see if switch is bad
Apr 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman yard tractor runs but take foot off brake it dies.....
Check the under seat switch. The switch sometimes fails and this cuts the ignition except when the foot brake is down. You can use jumpers across the switch wires to test it.
Apr 18, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
136 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
