Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
What does the code pf stand for? This has happened a few times My only thought was power failure but that hasn't been the case
  • Frigidaire Master
  • 43,501 Answers
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Posted on Mar 07, 2011
How can I determine the cause of the error code on my Kenmore Free Standing Electric range, Model # 911.9344190? Error code is PF.
PF stands for power failure. Check the voltage at the wall outlet and make sure the connections are tight at the terminal block...
Dec 31, 2016 | Kenmore Kitchen Ranges
What is wrong if my Frigidaire front load dryer
Thank you for your inquiry, friend!
I understand that your Frigidaire dryer has been providing you with an error code "PF". Typically "PF" stands for power failure this can happen if power is shut off during a cycle or the dryer receives insufficient power, which could be an issue with your power cord or control panel. Let's perform a reset on your dryer and you can do this by unplugging the power cord for ten minutes. If you need any additional assistance please feel free to reconnect. -Matt
Oct 14, 2014 | Dryers
Frigidaire dishwasher pf dims and stops
Hello Colton Rawlings, thank you for your post!
Based off what you are describing "PF" stands for power failure on a Frigidaire dishwasher. If the lights are dimming then your appliance flashes "PF" it could possibly be an issue within your panel or your appliance is not getting enough power to it. I would recommend contacting a professional to come and diagnose your appliance properly. I hope this is helpful. -Matt
Sep 06, 2014 | Frigidaire Dishwashers
My dishwasher has pf code every use and doesn't finish. It seems to happen when pump kicks in and doesn't sound good. Could bad pump cause pf code
PF stand for power failure...and only occurs when voltage is lost to the main control... First thing I would do is shut the power off to the dishwasher and check the main power connection going to the dishwasher, I have seen those wire nuts come loose and melt.
Far as the pump causing it, I wouldn't think so.. its more likely its just tanking some time for the wire's to heat up before the connect is lost (about the time the drain cycle starts)
If not I would recommend a pro come out and look at it.
Mar 08, 2014 | GE Dishwashers
PF code comes on
Check all the wiring to the dryer and even the wires in the wall socket. Sounds like there is a loose wire since you keep getting the power failure (PF) code on the dryer.
Dec 27, 2011 | Whirlpool GGW9868K Gas Dryer
What does PF stand for? getting that message several times lately
What you could do is get the service panel off the base of the machine.
On the backside of it is the tech sheet which gives explanations of the codes given.
You would thin it stands for Power failure and it might just be a faulty breaker. They recommend the washer have its own dedicated line without any other things on that line. Some codes require a ground fault interupter on the receptacle near any machine that uses water in case of flooding. That could be causing the PF. themobilian_2.png
Nov 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Frigidaire dryer says pf
pf stands for power failure
Jul 11, 2009 | Frigidaire Electric Dryer
Code
The PF stand for Power Failure. When you unplugged it, it truely did have a power failure..
Nov 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
289 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
