Question about MA Audio HK4000D Car Audio Amplifier
My m.a amp whont work. The protection light turns on. what could be the problem
  • 1,940 Answers
The protection light comes on when a wire is crossed, shorted, loose, etc. Check your wires, and then double check them, at the amp, and from the head unit, you may have a short or loose connection. If you have any kind of Y adapter on your RCA cables, this could also cause this problem.
It could also mean your amp is dead. If this is the case, get it serviced.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Jul 14, 2010
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
Sat nav tontom one whont charge or come on
Your battery has probably gone and since it is a Li-ion battery, it has sent a signal to the TomTom not to turn on. This is a battery protection circuit in the Li-ion battery. You probably have to replace the battery
Jan 29, 2011 | Car Audio & Video
Tc whont turn on the light wont turn off abs light wont turn off
Your ABS system has detected a fault in the system. When that happens, the TC is automatically turned off. You will have to have the ABS diagnosed and repaired before the TC will come on again.
Good luck.
Jan 17, 2011 | 2005 Hummer H2
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Hi i just bort loncin 110cc auto it has spark
hi this is your piston rings thanks or try adjusting the lifters first
Nov 23, 2009 | Car Audio & Video
I have an older red sony xplod 500w 4ch amp. the power/protection light is glowing red. what does that mean and how do i fix it? I have no sound.
The protection light comes on if the amp overheats or if the speaker outputs are shorted.
Turn everything off and check all of your speaker wires for shorts. When you locate and repair the short, the protection light should go out and your amp will work normally again.
Hope this helps!
Mar 26, 2009 | Car Audio & Video
Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Mar 22, 2009 | Car Audio & Video
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
Open Questions:
MA Audio HK4000D Car Audio Amplifier Logo
104 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
