SOURCE: RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
SOURCE: Need Hitachi TV code(s) for GE Universal Remote #24912 - thanks!
here is the 2 links for the codes, they are pdf files. hope this helps
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-New.pdf
SOURCE: NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I HAVE A GE UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM A SONY TV
SOURCE: code for jvc tv with ge universal remote
Here are the GE Universal Remote 4 digit codes for a JVC TV.
0060... 0026... 0197... 0069... 0160...0247... 0923... 0012... 0065... 0067... 0141
Direct Code Entry
1. Press and hold the SETUP
button until the red
indicator stays on, then
release the SETUP button.
2. Press and release the
desired Mode button (TV,
VCR, etc.). The red
indicator blinks, then
stays lit.
3. Enter the 4 digit code from
the code tables. Note:
after a valid code entry,
the red indicator turns off.
For an invalid code, the
red indicator flashes.
4.With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of the
other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for 3 seconds.
Hope this helps!
Sincerely, CBR2009
