Question about Amcor AF 12000E Portable Air Conditioner
We purchased a Amcor Amcoraire Mini Split Unit ? 12000BTU However the Power transformer input: AC115-120v 60hz Output: 10.5v 550mA isn't working as per the installer and we can't seem to find it anywhere. Any help?
  • 73 Answers
We stock the Amcoraire Transformer that you need.
The Pridiom Group
201-266-8234
Posted on Nov 03, 2010
E7 code on amcoraire mini ductless unit
E7 i= "External Feedback Problem" which is a communication problem. There is a cable from the outdoor unit to the indoor unit ,check that cable is secured to the unit,check connections for tightness.
Here is the manual including instructions.
http://www.acwholesalers.com/EasyEditor/assets/amcor%20duo%20uchw-h12%20owners%20manual.pdf
Nov 08, 2015 | AmcorAire UCHW-H18AF2 Split System Air...
Split AC system not cooling.
P-7 Error Code means: DC Voltage Problem in the outdoor unit.
Bad PFC & IPM Circuit Boards.
The Pridiom Group
201-266-8234
Jul 26, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
At AmcorAire Conditioner the circut panel has burned. How I can replace it?
We stock a complete line of parts for the Amcor Mini Split Systems.
Support@Pridiom.com
201-266-8234 option2
Jul 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
We purchased a Amcor Amcoraire Mini Split Unit ? 12000BTU However the Power Transformer Input: AC115-120v 60hz Output: 10.5v 550mA isn't working as per the installer and we can't seem to find it...
Hi, this is a 1-ton cooling unit per your numbers. If they just installed it and the line side (120 volts) is good but nothing on the secondary low voltage side, they should have replaced the transformer themselves? If it is a split system, it is normally on all splits to be located in the indoor unit control section. I can't tell you exactly, but look where the 120 volts come into the indoor unit and the high voltage wiring should be connected to it then stepped down to lower voltage. It may have a fuse on the circuit board that they blew when installing it. If you are not familar with electrical, I wouldn't attempt to make these repairs. You can look for a small plug in type fuse to see if it blew, it looks like one on your automobile. I would call this installer out and its there job to do this!! These transformers look different, there not all the same, but will have a black and white wire coming in, and several colored wires coming out for low voltage. It will be in the indoor unit. Keep me posted on what you find or if you need more help. How long ago was the unit installed?
Shastalaker7
Jun 15, 2010 | Amcor AF 12000E Portable Air Conditioner
Air circulator not working on unit
We stock a complete line of replacement parts for Amcoraire Mini Splt Systems.
Support@Pridiom.com
May 28, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Amcor split air conditioners
This should work find both being 230volt The best is to have it on its own breaker. Thank you J
Dec 19, 2008 | AmcorAire UCHW-H12AF2 Split System Air...
AMCOR Parts
Pridiom Group, New Jersey has all parts & tech support
Sep 30, 2008 | Amcor Heating & Cooling
Amcor AF 12000E Portable Air Conditioner Logo
124 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
