Question about Uniden Solara DSC VHF Marine Radio
With engine running on boat, radio transmitts with
With engine running on boat, radio transmits with a lot of static. Engine off the radio works great.
  • Uniden Master
  • 696 Answers
This is almost always caused by a poor ground. I would suggest you run your ground wire (larger the better) back right to the negative terminal of the battery.
Hope this is helpful.
Posted on Sep 09, 2010
Comon problem with aircrafts ...use a shielded Ignitiion cable for your plug leads.....also a inline capacitor will dampen out the noise.
Posted on Aug 26, 2012
How do i correct engine noise while transmitting on a cobra MR F45-D marine radio
you'll need a filter capacitor in the power line to the radio. wiring varies according the the individual unit, but typically one side to power, the other to ground.
Nov 29, 2014 | Cobra Mr F45-d Marine Class-d Dsc...
Work fine for about 5 minutes than change to static
There's an auto-shutoff feature which kicks in when the audio input to the transmitter is too low. That's usually indicated by the green light on the transmitter turning off. Just increase the volume on the device connected to the transmitter, and you should see the green light come back on. As long as that's on, it'll stay transmitting and shouldn't just cut out to static.
Jun 25, 2014 | Sennheiser RS 120 Consumer Headphones
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
I have a cobra 29 ltd chrome and it making a lot of static noise while driving or idling. it transmits and recieves fine though
Hi, my name is John. Welcome to FixYa. Try running your power strait from the battery, that will bypass a lot of your noise. RED (+) ground (-) . Thanks for choosing FixYa....John
Nov 30, 2010 | Cobra 29 LTD CB Radio
Static on am radio (comes and goes). fm is fine. 99 Subaru Legacy Wagon.
A static on AM is just interference. Similar to operating a mixer when you are watching TV. You would remember the grains in the TV but no audio disturbance because, video is AM transmitted and audio FM transmitted. A static on AM radio could be due to many factors in the car. The ac system, the music system itself or the engine rpm. The solution does not lie in finding out which is creating the noise, it lies in insulation. Check the antenna and change it if needed. That should fix it.
Jun 19, 2009 | 2004 Subaru Legacy
Can not hear people through static from radio.
no,its in the radio.i have had a lot of radios,and i have had several with just too much noise.its in the radio.i would not go by what a trucker cb shop says.contact company,or try and sell it and start over.i have had to do that also.
Feb 15, 2009 | Connex 3300 240-Channels Base CB Radio
Not transmitting or receving (transistors burnt out)
if its not transmitting or receiveing its probably a problem in the power supply or antenna/coax.The big transistors you see inside are the output transistors for the transmitter section and would not effect the receive. Does it pick up static with the squelch is open? if so the audio section probably works ok.Have you tried a watt meter with a dummy load to see if the transmitter is working?Before you change components you have to narrow down what section is not working and know why its not working otherwise the new transistors could just blow too if its transistors that are bad.more information is really needed to diagnos the problem.
Jan 15, 2009 | Cobra 29 LTD CB Radio
How to set up fm transmitter for sanyo gps nvn-4370
At the main menu press settings
press FM Transmitter
Turn transmitter on by pressing off. Will change to On
Press the Frequency button. Than change the frequency to one that doesnt have a radio station.
All sounds from the GPS will now be transmitted to the frequency set. Make sure your FM radio is set to the same frequency.
With my one vehicle this option does not work very well & is full of static because my radio entenna is at the rear of the car. The GPS only transmits a couple of feet.
Dec 27, 2008 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Turning on my Lowrance LCX 111HD fish locator creates static with my ICOM M502 VHF Marine radio.
Hello LJones0455. From your detailed attempts there are few options. Position the transducers one foward one aft. Connect the negitives of the battiers to the boat still route both positive & negitive wiring to all devices. Check the continunity of your transducers include flexing while ohming. Let me know of the results.
Oct 07, 2008 | Boating
Uniden Solara DSC VHF Marine Radio Logo
272 people viewed this question
Top Uniden Boating Experts
Steve
Steve
ray gallant
Sock Puppet
Are you an Uniden Boating Expert? Answer questions, earn points and help others
