Question about Zenith Metal& Shower Caddy
My cascade manual power shower control knob is broken so its completely impossible for me to use the shower. Can i get replacement control knob to buy?
2 Suggested Answers
packrat1948
  • 528 Answers
SOURCE: I see quite a few
Well I like everyone else looking for these parts con not fine anything on the net. The only thing at this point is to go to a place were these are sold and see if they have a web site or phone number to look up or call. I think somewhere on the unit there should be an information sticker with model numbers and such.
Posted on Feb 11, 2011
When I turn the dial to put shower on the temperature dial is now moving with it so I don't know what temp it is! I have a triton power shower.
Thank you for supplying a picture. The two controls could be binding. Try holding the temperature setting with one hand while turning the shower on with the other. If this doesn't work, you may have to remove the knobs to find what is causing them to bind. The upper knob may be attached too tightly, causing it to bind on the lower knob.
Jan 26, 2015 | Home
Why shower won't shut off completely
Chances are, the rubber seal is worn on the control knob. Make sure both hot and cold knobs are turned off. Take the handle off the shower control. Take off the chrome ring. You will see a nut around the shaft. You will need a special socket to take loosen the nut. If the hole is large enough you might get a pair of plyers on the nut. This will let you pull the control shaft out and replace the washer. Make sure you use a flashlight and see if the seat is damaged before replacing. Make sure you tighten the rubber very tight, as it will tend to loosen.
Aug 03, 2014 | Delta & Stem Unit Assembly
Plastic knob "grohmix" on shower has broken into
Ferguson plumbing supply can order this part for you
Oct 26, 2010 | Grohe Home
I have replaced the o ring that was broken.still leaks
on the outer of the stem there should be a hard plastic washer. Is it there? If not that is the problem. Or you may need to tighten the packing nut. (the farthest nut out on the stem towards the handle).
Nov 08, 2009 | Cascade Faucets Cascade Style Cr1 3x12...
Heat a/c problem
Hi.
I assume that you are having issues with the heat controller; which is a very common problem. And, it costs over 900 dollars to replace it, when all is wrong with it are 2 broken wires.
Unfortunately, you have to completely remove the heater controller from the dash, and completely disassemble it to gain access to the 2 wires that need soldered, it is impossible to gain access to the wires with the unit in the dash. When you get it apart, look for 2 broken wires at the sub-PC board (from the knob) going to the main PC board. Also, to avoid having these wires break again, make sure that the nut behind the knob is real tight; if it is loose, it allows the board to rotate, and snap the wires.
I would recommend that you reserve a day for this project.
Thanks for choosing FixYa for your solution.
Oct 08, 2009 | 2005 Toyota Highlander
Shower head dripping cant turn shower knob off
Mixer valve needs repair. special tools required.
Aug 21, 2009 | Home
Replace inside stem on hot water Eljer shower faucet
Sounds like you might need a gear puller -- hardware stores would have them -- or auto parts.
Spray with contact cleaner wd-40 first, then install puller, depress ring and crank away at the puller.
Apr 21, 2009 | Home
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Zenith Metal& Shower Caddy  Logo
159 people viewed this question
Top Zenith Home Experts
john h
Tom Chichester
Are you a Zenith Home Expert? Answer questions, earn points and help others
