Question about LG 42PC5D Television
My remote quit working with the LG 42LG50 tv. The remote is good. I replace the sensor pad in the tv and still does not work.
  • ronpat1 Jul 14, 2010
    Thanks I will check it out. The remote does work on anothe rTV.
  • 10,594 Answers
Please check LG remote on another LG tv to confirm that remote function is fine.
Check volts with multimeter on IR sensor it should be 3.3V or 5V
If volts are fine then replace main board as Microprocessor on main board got defective.
Let me know if you have additional question.
Thanks.
Posted on Jul 14, 2010
  • 2,335 Answers
If you are using a universal remote, I suggest re-programming it with LG remote codes; if it is factory remote I recommend resetting it to factory condition.
Unless you have a second LG 42LG50 television you can test the remote on, I am not sure how you can be sure the remote is functioning properly in TV-mode. But until you can confirm the remote is not sending valid TV control commands, I would be reluctant to advise you replace more parts in your TV.
I suggest taking the remote to a store that sells your model of TV if possible and trying it out there to be certain the problem is in your television before further TV part replacement.
I hope that helps.
How do I reset my LG TV remote?
there is no reset on remotes TRY NEW BATTERIES
Oct 06, 2015 | LG 42LG50 42 in. LCD HDTV
How to replace the IR sensor in a 42LG50 tv
how do you know the remote is working properly if it won't work the TV
Jun 01, 2015 | LG Televison & Video
TV wont shut off with remote
verify if the remote is working first and then check the receiver unit
Apr 10, 2015 | LG 42LG50 42 in. LCD HDTV
My lg tv model 42lg50 will not turn off with the remote or the manual switch on the tv. I can not get the tv menue to come up from remote or manual button on side?
Its a failure possible from the button module
Posible solution is to replace the module
you could check it by disconnecting it
Hope this was helpful
Aug 11, 2014 | LG 42LG50 42 in. LCD HDTV
Renting condo. cannot get channel back to 3 so cable will work
Turn the TV off and then back on. Enter #0 #3 on the LG TV's remote and then push the OK button the remote.
This will force the TV to go to channel 03 on the TV.
Good Luck.
Jun 28, 2010 | LG 42LG50 42 in. LCD HDTV
I need the remote code to work the volume button on bt vision with my lg lcd tv
good day if that remote you have the original on your tv , no need to search a code, code only apply when you using the universal remote. maybe your remote needs cleaning the board, so that all button will function
Jun 20, 2010 | LG 42LG50 42 in. LCD HDTV
My lg 42pc5d tv remote sensor quit working. I am
Check on the back of the TV to see if you have a "remote in" port. It will look the same as a 3.5mm headphone jack. Unplug the TV and plug a pair of headphone into the port and then remove it. Do this several times to breakup any debris that may have gotten into it or corrosion that may have occurred in the port. If something is in the port it will disable the standard remote sensor on the TV.
Jun 04, 2010 | LG 42PC5D Television
Cannot turn on or off the tv with remote,can't turn up or down vo
It sounds like either the remote is no good or the ir receiver in the TV has gone bad. try new batteries, or even a universal remote. this will help tell you if it's the TV or remote, good luck
May 31, 2010 | LG 42LG50 42 in. LCD HDTV
Remote not recognized by TV. Brand new model.
An easy way to tell if the remote is bad or not and I know this sounds funny. Put the remote next to a small am radio tuned off a station if you hear a pulse when you press the buttons on remote it is ok 95 % of the time. If this set is new just simply call LG or get an authorized service center to replace IR sensor in TV.
Apr 12, 2009 | LG 42LG50 42 in. LCD HDTV
Televison & Video Logo
220 people viewed this question
