Question about Metabo ® 12 Amp 9000 RPM Model WE14150 Quick 6" Electronic Angle Grinder With Locking Paddle Switch ® 12 Amp 9000 RPM Model WE14150 Quick 6" Electronic Angle Grinder With Locking Paddle Switch
I had been using this grinder for about 2 weeks with no problems. A few days ago while using it it just popped and hasn't worked since.
    Problem Solver:
  • 5 Answers
The part number for the replacement brush from Ohio Carbon Industries is #20-870 and they are $3.53 each or less depending on the quantity purchased. We do have a minimum order. Ohio Carbon Industries is a manufacturer and distributor of carbon brushes for nearly all electric motors. Call our sales dept. at 419-496-4456 or email them at sales@ohiocarbon.com.
Posted on Mar 20, 2012
  • 760 Answers
These are great grinders. I have two of them. One version (more expensive one) has soft start and good overload system. Other version is basic grinder. if it (popped) most likely a short in the motor. Is it possible you got an unusual amount of grinding dust into the grinder? This grinder has a safety feature on the brushes, that keeps from burning up the armature when the brushes wear out. I doubt you've worn out a set of brushes in 2 weeks, unless you've been using it non stop. At least one of the brushes has a small plastic insulating pin inside the carbon. When the brush wears down enough to expose the plastic pin, the spring loaded pops out, lifting the brush from the armature , which opens the circuit. You could remove the brush holders and inspect the brushes. If it is 2 weeks old it is under warranty, and you should return it where you bought it.
Posted on Jul 14, 2010
The air conditioner will not cool
if you are only getting 2-3 days out of a charge of refrigerant, it is likely you've got a pretty decent sized leak. Most likely the condenser, as I'm guessing that hasn't been replaced yet since it is probably the hardest part in the a/c system to access. it could also be bad o-ring seals at any juncture in the system. if it has been going in for 9 weeks and you still have a leak that bad, I would recommend specifically asking them if they are using a UV dye, and if they have used a refrigerant "sniffer" inside the weap holes where condensation runs out from the condenser... I had a similar problem in my pontiac a few summers ago, they found the leak in my condenser using their refrigerant "sniffer/detector" device by sticking it up in the weap holes, pretty expensive to repair.
on a side note, there is a stop leak that you can buy at almost any autoparts store, called "super seal". most garages will advise against it, but the guys at my local "big name" autoparts store, swear by it for the big leaks in expensive places.
Aug 29, 2012 | 2000 Buick LeSabre
The gas gauge on my 92 Dodge Grand Caravan stopped working over the past two days. Two days ago it seemed to be fine. Yesterday it indicated that I had a quarter tank when it should have been 3/4 like the...
worth checking the fuel tank for holes or there might be some fuel delivery pipes leaking badly. Or it might be an O2 sensor not giving correct signal to ecu thus consuming so much fuel.
Jul 11, 2011 | 1992 Dodge Caravan
Suddenly, No tail lights, brake lights, turns signal or back up lights At 83000 miles, 6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen...
just look for the blackened/burned pin on the rear light plastic connector and sand it down to re-establish a good electrical connection and save yourself $800 big ones on replacing the multiswitch.
Jun 26, 2011 | 1999 Chevrolet Venture
6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen sensor. Cleared code. 3 weeks ago, got oil change, replaced headlights and replaced...
CHECK TURN SIGNAL FUSE.IT COULD BE BLOWED OR YOU HAVE FAULTY TURN SIGNAL SWITCH.BECAUSE BACK LIGHTS AND TAIL LIGHTS SHARE SAME CIRCUIT WITH TURN SIGNAL SWITCH.
Once in a while my grinder W7-125 doesn't start, then I'll have to losen the carbon brushes, put them in again, and now and then the grinder starts again and now an then I'll have to repeat...
I would look at the switch action sometimes the rod doesn't want to fully engage the actuator. Also look for debris that might be in the brush area. And lastly look at the brush shunt/spring to ensure there are no restriction to the shunt (wire) that will not allow it to easily move in the brush holder. The brush should slide with no pressure in the holder. Let me know if you need more assistance.
May 08, 2011 | Metabo W7 125 Angle Grinder 5" 9,000 Rpm...
Grinder does not stop
I need more information to solve this.
If you mean the grinder just spins but doesn't seem to be grinding anything - and then after 30 seconds or so it tells you the bean hopper is empty - then the problem is sticky, oily beans that aren't sliding down into the grinder.
You want to buy freshly roasted (roasted less than a week ago) beans. Coffee beans from the supermarket are old, stale and sticky with rancid oil. Even Starbucks and Peets - although the sign says "roasted daily" if you read the fine print, the beans in the store are rotated out 90 days after roasting. The oils turn rancid and get sticky after a couple of weeks so you really need to get beans from a local roaster or order them from a roaster who ships them fresh.
I have been using RedBird espresso blend and these beans work perfectly with this machine. They also are the best tasting of any espresso blend I've ever tried. The price is reasonable (cheap even) and the roast date is written on the bag. I get my beans 2 days after they were roasted.
http://redbirdcoffee.com/redbirdespresso.html
In the meantime, until you get some coffee beans that are not oily, you can stir the beans in the hopper. Use a wooden coffee stirring stick or a chopstick and just lift the hopper lid and stir the beans so they slide down into the grinder. You will probably have to do this before each coffee and maybe even 2-3 times just to get one coffee.
Once you get some fresh roasted beans that don't have that oily shine to them you will be grinding without any problems.
Oct 22, 2010 | Gaggia Titanium Espresso Machine
Popping sound on my toshiba 32" flat screen
pls. cheked
1. suond ic input supplay voltage (ic B+ voltage regestance 1 ohm.
and capacetar 2200um/35v replace)
Oct 04, 2009 | Zenith R57W46 57" Rear Projection...
New Dremel 300 stopped working. What's wrong?
Something amazing just happened! On my monitor screen, window popped up that said, "ASK A QUESTION - LET OUR EXPERTS SOLVE YOUR PROBLEM FOR FREE".
I couldn't resist getting expert advice for free, so I clicked on the window. I was immediately taken to a magical world where I can pay for expert advice. I opted not to pay for expert advice. The next day, I was asked if the help I received was helpful. So here I am posting this response. I haven't received any expert advice yet, but when I do....!
Jun 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Metabo ® 12 Amp 9000 RPM Model WE14150 Quick 6" Electronic Angle Grinder With Locking Paddle Switch   ® 12 Amp 9000 RPM Model WE14150 Quick 6" Electronic Angle Grinder With Locking Paddle Switch Logo
362 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
