Question about Toys
Can 4 neon tetras 2 bala sharks and 10 ghost shrimps fit in a 10 gallon tank
4 Suggested Answers
Jack Dye
  • 268 Answers
SOURCE: Ghost Ship
Hey Fee
email me and i will send you the walkthrough straight to your inbox on a word document, remember to specify, i have helped over 100 people that have emailed me with gaming problems
jackdye@yahoo.co.uk
Posted on May 27, 2008
  • 6982 Answers
SOURCE: tank problems 86 grnd wagn runs out of gas
You are going to have to remove the fuel tank and check the pickup in there. Either it was bent or altered by someone or part of it has rusted and fallen off. i don't remember if you have injection on that engine but likely you don't. In that case you can just put a piece of rubber fuel line on the pickup and extend it down further. Always angle cut the end so it won't end up flush with the tank bottom or wall. I usually attach a weight on the end to keep it on the bottom. (I generally screw a large diameter nut over the rubber hose) Though the "sock" filter on the pickup is a good thing to have, you can add a good in-line filter before the fuel pump to keep dirt out of the pump and carb.
Always be careful not to damage the sending unit when you have it apart. If the float or float arm gets bent it will not read properly.
Posted on Jan 23, 2011
c1apton15
  • 3400 Answers
SOURCE: can't get fuel in my
the vent tube is plugged(small tube next to filler tube), you need to blow out w/compressed air.
Posted on Mar 23, 2011
What is belt size for shark rotator model NV341
Hello, this is Ava with Think Crucial.
I don't have the exact size of the NV341 belt for Shark however, you may order the belts for your Shark and other replacement parts directly from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
2 Shark Belts Fit NV350 HV400 NV500 Series
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 07, 2016 | Shark Vacuums
Can the Marina i25 be used in a small saltwater aquarium?
: You could but a few shrimps is all you could keep in there and it would be a very small marine tank .An experienced fish keeper could mange that but i always advice 30 gallons minimum for starting a marine tank .
Jul 27, 2015 | Fish
Tropical tank 75 ltr ??
You are 9in the wrong catefgory. Please repost.
May 02, 2013 | Cars & Trucks
My air pump still has air coming out just not as powerful, this is the second one in less than year that has down this. it is just a 2 gallon tank.
You can get overhaul kits for these pumps and DIY. cheaper than buying a new pump. Your pump should last longer than that. your pump is really big for a 2 gal tank. how are you adjusting the air flow? If you throttle down the air flow a lot on a diaphragm pump, it can shorten the life of the diaphragm
Dec 15, 2012 | Fish
Do you have a manual for a Tetra DHP 4200 pump?
No. This site has no manuals. And as simple as this pump is, neither does Tetra.
Jun 29, 2012 | Tetra Pond Debris-Handling Pump DHP4200...
Can you clean the clear tube that seperates the UV bulb from the water in a Tetra Green 2 UV?
A test tube brush or a small bottle brush will fit and not damage anything. Alternatively as long as it is not used for saltwater soak in a bucket of 5 gallons water and a 1/2 cup of bleach will kill and separate any algae. Just rinse thoroughly to flush out any leftovers and to clear the unit.
Apr 10, 2011 | Tetra Green Free Uv - 2 Clarifier - 18...
How to remove fuel pump on Neon 1998 ? can I reach from inside the vehicle ?
on a dodge neon the fuel pump is in the SIDE of the tank... NOT the top. to remove the pump follow these steps...
******* first unplug battery and remove ********
1. unbolt passenger side tank strap and lower side of tank.
2. a. if tank is plastic, CAREFULLY unscrew plastic retainer ring but do NOT remove.
b. if metal tank, unscrew metal retainer flange but do NOT remove
3. unplug electrical connector and fuel line from pump. move aside.
4. completely remove retainer BE CAREFUL not to disturb pump.
5. have drain pan or wide-shallow bucket available to collect gas. (if tank is full this will need to be able to hold 7-8 gallons)
6. gently twist and pull pump out till gas comes fourth. catch gas in pan/bucket.
7. remove pump when gas stops flowing.
8. install is reverse of removal.
9 BE CAREFUL not to wrinkle gasket or lose gasket into tank when installing or the tank will leak around pump.
10. tighten retainer but DO NOT OVER TIGHTEN.
11. reconnect plug and fuel lines check for leaks.
12. reattach tank strap and fasten
13. refill tank with clean gas. check for leaks.
14. put battery back in. connect battery, start your neon and check for leaks one last time.
15, have fun. this will take about 4hrs to do by yourself with proper tools.
Apr 24, 2010 | 1998 Dodge Neon
Tetra filter Leaking after cleaning
Tetra tech support can help you or email you a new owners manual. Call their toll free number 800-526-0650
Jun 23, 2009 | Tetra Garden
Gas Mileage/Tank on 1992 S-10 Blazer
I am finding that you have a 20.0 gallon fuel tank....2 or 4 dorr....doesn't matter.
Please don't forget to rate.
May 13, 2009 | 1992 Chevrolet S-10 Blazer
Toys Logo
27 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
