Vtech kidszoom camera changed batteries turned it back on and screen lights up but is white - no menus or pictures will display is it broken?
Probably not, I have fixed several digital cameras by doing this. This is for a GE E1235 but screws and other stuff shouldn't be hard to find.
Well I
decided to fix it my self.
1st: Take out all the screws (7 total) one is hidden under the av out
cover. Make sure u mark all the longer screw heads and location with a
marker so you know where they go. There were only to sizes so if you
mark the longer ones you should be ok.
2nd slowly pull the back of the camera back (BUT BE CAREFULL, do not
pull to far there are wires from the LCD and buttons to the camera.) Now
there is a little tab on the main board holding the wires from the LCD
to the camera. Flip it up and remove the LCD wires. After you do that
push the LCD wires back in and flip the tab back down. Be careful not to
damage wires or tab. Put case back together, put screws in where they
go, and wallah. Your camera should work. If not try again, and make sure
your properly putting wires in. If it doesn't work email me I will be
making YouTube video for this soon. REMEMBER TRY AT YOUR OWN RISK!!! I
AM NOT RESPONSIBLE FOR ANY DAMAGE YOU CAUSE!!!
