Question about Whirlpool Home
Looking for plastic connectors for jets on ax8085 tub room
    Problem Solver:
  • 3 Answers
Check online. a hardware store near you might have it on sale
Posted on Jul 15, 2010
The casing around the jet on the tub side is cracked and is causing water to leak on the outside of the tub. This has happened to three of the 10 jets. What can I do to fix this?
Cheap plastic fatigues with heat . Silicone will work but will not keep the crack from continuing. The fix depends upon what type of plastic you have . It is likely a polyester like fiberglass in which case you can use regular fiberglass to fixit . Rough up the outside with 80 grit , brush in fiberglass resin ( don't forget to mix in hardener) lay in glass material , repeat until built up . Repair the front with a good "gelcoat " repair kit which allows you to mix match color.. sand with 220 , then 600, then 800, then 1500, then 3000 , polish with automotive whit polishing compound , wax
Nov 14, 2017 | Jacuzzi Home
Have an older jet spa tub where do I get new gold rings for around jets
Click on the Link below. Jet Trim have to be matched up by sight.
Find the brand name of your bahtub and click on the name.
http://www.uspartscenter.com/category-s/4954.htm
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: photos@uspartscenter.com
Rod
US Parts Center
888-521-6183
Feb 20, 2013 | Home
One of the small jets is leaking water on the back side. There is a big plastic nut I'm not sure will loossen to allow repair. The plastic piece going into the jet fitting looks a little cocked and that is...
It sounds like the plastic nut is cross threaded and may be hard to remove but you can always use a hot knife or soldering iron to cut through it and replace with new.
Good luck
Feb 06, 2011 | Jacuzzi Bellavista Whirlpool Tub EE20
Need replacement parts for a MAAX WESTCO INC A159869 8Z31 Jet Bath Tub Would like to replace the white plastic parts in side the tub with chrome as they have turned yellow
Try Guillens.com or usparts.com I have had some good luck finnding jets. Maax is still in business and you might be able to get the jet directly from them, although they are in Canada. Hope this helps.
Aug 11, 2010 | Home
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
I have a leaking jet in a pearl jet tub. it's an older model with just two jets installed in 1997 the jet leaks and i don't know how to jet the face plate off the jet, or have a diagram as to get the jet...
If there is a  threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no  threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Sep 28, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Want switch on
want switch on WHAT? need more details, type of switch is it digital, air or vacuum ETC.. switch to light ,switch to jets or switch to jet flow????????? Its there a wall switch on wall of bath room or gfi breaker for tub?????
Jul 08, 2009 | Jacuzzi Home
MAXX code E01, jets don't work
well first of all i have to assume that this tub is equipped with jet's on the floor and lights,if not then there's no reason for it those buttons to light up, now if it is equipped with these features and your getting a error code all this means is that this tub need to Re Configured to run this type of system,this is something a tech needs to look at because you wouldn't be getting error codes if the tub was configured wrong the reason your getting error codes is because something isn't plugged in correctly at the control box and the computer detected a fault.
Justin 503-547-3483
Mar 13, 2009 | Maax Calla 6042 Bathtub - 101058-000
Home Logo
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
