Question about Hitachi 57F710 TV
The picture keeps growing larger than the screen.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 14, 2010
  • debrapat Jul 14, 2010
    Is this the only option I have to fix my tv?
  • Rylee Smith
    Rylee Smith Jul 14, 2010
    Yes
How to fix err over flow massage when calculating e^?
The function grows very fast and your calculator cannot handle number larger than 10^100. This puts a limit on the argument of the exponential.
e^230 is about 7*10^99 and e^231 overflows the memory.
Now, that you know the calculator limitations keep the exponent less than 231 and you will not have the error message. Of course, if you multiply e^230 by a number larger than 1 you will exceed the limit.
Also, to get the exponential, you press [2nd][LN] and you do not press the caret key [^].
Mar 18, 2012 | Texas Instruments TI-83 Plus Calculator
What is the best grow lights to grow *********
That depends on what you're trying to grow and what phase the plant is in. Certain plants are adapted to grow in the shade or in warm, sunny environments. Depending on the plant, one type of light may work better than another. For example, if your plant needs a shadier environment, then a regular incandescent bulb may work best.
The other factor that goes into choosing the right grow light is what phase your plant is at. For example, a high-pressure sodium bulb may be best when your plant is in the flowering or fruiting stage.
Personally, I love using LED grow lights. Modern LED bulbs are more energy-efficient (they produce more light with less power), so they cost less in the long run. They also produce less heat, which means you don't have to worry about a ventilation system. Plus, they emit light wavelengths that correspond to the peak absorption peaks for most plants.
When choosing your bulb, you should look at the requirements of the plant and how those requirements change as the plant continues to grow. Keep in mind that the larger your plant gets, the more light it will need, so plan ahead.
Feb 07, 2012 | Jump Start 4' Fluorescent Plant Grow Light...
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
My 47 inch lcd tv screens goes pitch black randomly for a few seconds at a time, no reason. The sound is still audible in the background so the probelm is just with the picture. any suggestions
Either 3 boards may cause this issue and need servicing before it grows into a larger more expensive problem.....
Inverter boards
power supply
Time control board
Its a sustain problem and a really easy repair shouldn't cost too much.........
Nov 03, 2009 | Televison & Video
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Black mark on screen
The only way is by changing the panel.
Apr 07, 2009 | Proview HX303 30 in. HD-Ready LCD...
My JVC 56G787 is dark and bright is turned all the way up
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | JVC HD-56G787 Television
Screen goes black, picture grows over time but is dark
i suspect that you have a problem in the yb board that's the first thing that i would do.
good luck
caypianan@yahoo.com
Oct 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
Cracked screen
I've had my enV for about a year, now. within the first month, I cracked its screen. I have both insurance and a warranty for it, but Verizon is unimpressed-- they suggested that I either purchase a new model, or perhaps buy the enV 2. it's whatever.
Feb 28, 2008 | LG enV VX9900 Cellular Phone
Blue color area growing on screen
For any of you experiencing blue dots, lines, growing blobs see the following link:
http://esupport.sony.com/US/perl/news-item.pl?news_id=206
Nov 25, 2007 | Televison & Video
Hitachi 57F710 TV Logo
13 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
